Shaft Drive TC
#46
At club level racing it's driver and not the car.
Once you are good then the car comes into play. And well the pros run what they can win with. So what pro's run a shaft drive?
#47
It isnt a factor of what the Pros run, but what the factories dictate, what they pump the most money into AND what performs. Just two short years ago, Atsushi Hara was smashing people with the Pro 4...that would be 2005. Then, some genius over at HPI figured he would really push the Cyclone to the limit. Following Xray, Tamiya, Yokomo and Corally, folks got away from shaft because of torque steer. Yes, belts give you more tuning options and better diff access in most cases. But as far as acceleration, shaft is better.
#49
Will torque steer be noticeable in 27T or 19T?
#50
Suspended
#51
Smooth is fast anyways and better on motor and batteries!
#53
Do you run on carpet?
#55
Originally Posted by ford_racing
With correct setup you can eliminate torque steer, I run a 4.5 with a TC4 and I have no torque steer.
Can share with us your gearing for running 4.5 on asphalt with TC4?
Thanks!
#56
#57
Originally Posted by edseb
Someone said Hara was fast in 2005 with his shaft car, yes he was, but he is faster with his Cyclone.
#59
It depends on the track but around 16 pinion, 78 spur for the smaller ones, upto around 21 or 22 pinion on larger ones
Appreciated
#60
Originally Posted by Jake S
well to go along with his new cyclone he has new 1.24+ packs.....i have noticed that moving from my ib3800s 1.21 to my wc 1.24 i had a huge gain in speed, i just need to get control of it in my irs tc3....
