Old 04-03-2007, 03:45 PM   #1
Default what car??? (haven't heard this one before huh?)
Here's the deal I'm looking into getting in to on-road electric. I have a nitro buggy and truck now. What I'm wondering if you had the money and were looking into getting into what would you buy. I don't want to waste money on buying starter stuff and then having to rebuy in a month. I'm wanting something that will compete. Electric 1/10 CLUB Touring Car is what the local track is racing. I have the money to buy but I don't want to waste money. any help would be appriciated. All the local hobby shop has in is a RTR tc4. So outside of that I will order on line.
bradwant2gofast is offline   Reply With Quote
Old 04-03-2007, 04:13 PM   #2
Tsquare's Avatar
A few more details would be helpful - what motor class will you be running, what type of surface?
Tsquare is offline   Reply With Quote
Old 04-03-2007, 04:24 PM   #3
PeteB's Avatar
JRXS Type R, $400ish well spent...
JRXS-R
GTB SS + 13.5 & 10.5
Trakpower 4900
Supernova
Nomadio
PeteB is offline   Reply With Quote
Old 04-04-2007, 05:56 AM   #4
ASPHALT OVAL
Here's the rules of the club
1. Chassis: Any 4WD Touring Car Design. Aftermarket Oval Chassis conversions are NOT allowed.
2. Body: Any 2 Door or 4 Door Touring Sedan type, 190mm and 200mm allowed.
3. Drive System: Belt or Shaft Driven incorporating a Internal Gear Ratio greater than 1:50 to 1.
4. Motors: ROAR Legal 27 Turn Stock, with Full Face Brushes. Serrated Brushes and any spring combination allowed.
5. Batteries: 6 cell, 4200 mAh NiMH maximum are allowed. Cells MUST be identifiable.
6. Any style of connectors, batter to ESC, ESC to Motor may be used.
7. Gear Ratio - External Ratio (Motor/Pinion) = Open.
8. Rear of Bodies may be cut out to within 1" of Rear Deck. No Windows may be cut out.
9. One (1) Rear Deck Wing typical with body type shall be utilized. Wing must be fastened to the rear deck of the body and not
directly to any part of the chassis. The rear edge of the wing or side dams may not extend beyond the rear of the body more than 1/2". No
part of the wing or side dams may extend above the roofline of the body.
10. Tires: Rubber Slicks or Tread Design No Foam, Caps or Radial Tires Allowed.
11. Minimum Weight (Battery, Body and Transponder Installed): 2lbs 9oz
thanks (keep it coming)
Old 04-04-2007, 08:33 AM   #5
UN4RACING's Avatar
Trader Rating: 22 (100%+)
I would go with the shaft drive. TC3 or TC4, The batteries mount on the left side. I think the shaft drives will carry more off throttle speed as well.
Especially with rubber tires.
UN4RACING is offline   Reply With Quote
Old 04-04-2007, 01:57 PM   #6
PerformanceRC's Avatar
Depending on what direction the track goes you can mount batteries and motor either side on the STR4 Pro2 for weight distribution.
PerformanceRC is offline   Reply With Quote
ANYONE HEARD OF THIS!! PLZ HELP chrisanton Nitro On-Road 6 12-19-2006 04:22 AM
ANYONE HEARD OF THIS!! PLZ HELP chrisanton Rookie Zone 3 12-18-2006 07:48 PM
ANYONE HEARD OF THIS!! PLZ HELP chrisanton Electric On-Road 0 12-18-2006 06:26 AM
Anyone heard of this?? Team Typhoon Monster Trucks 4 04-05-2005 04:39 PM
Has anyone heard of the AG FASTERTHENU Monster Trucks 0 01-18-2003 12:07 AM
