TC4 wheel options
Originally Posted by Raydee
Steve why won't they fit the fronts? I am thinking about going wider in the front and the rear and running a GTP style 200mm body...if it will work.
You will need a 28 or 30mm in the rear and a 26mm in the front, the 28 and 30mm will rub the arm....I run a 40 up front with a 35 in the rear...
