Old 05-09-2007, 08:24 PM   #91
Thanks Charlie, This GTB/Ribbed motor combo is an impressive package
catcars is offline   Reply With Quote
Old 06-04-2007, 04:19 PM   #92
Double Quattro's Avatar
Default GTB problems with motor plugs installed ?
It’s funny how these Novak threads always start with some drama and heated postings…anyways…
I just used the 1711 for the first weekend of racing and would like to offer what I experienced.
My intent was to use this ESC along with the 13.5 SS for two specific roles. I race brushed stock class but wanted to use brushless for practice and set-up runs. Originally I thought of using a pair of Deans plugs on the motor for quick change over between brushed and brushless. Unfortunately this didn’t work out so smooth.
I had a hard time getting the ESC to stay in brushed mode when I switched motors with the Deans motor plugs installed. Either the extra connectors/solder points or something else was making the car run intermittently in brushed mode. It appeared from the LED indicators that all was well but the motor would not turn (green LED on solid when I pressed full throttle as in normal operation) I would have to re-engage the mode selection process with the motor unplugged (per the manual) then plug it back in then it would work for a while. I actually DNF both of my qualifiers because of this.
So for the main I said enough with the plugs (wasn’t really convenient anyways) and direct soldered. The ESC has worked beautifully since. I figure this is the way to go anyways but wanted to try the motor plug option.
Anyone else have similar experiences or can offer a rational explanation for the intermittent operation with the motor plugs installed? I made sure the soldering was solid and obviously used the best low resistance plugs available.
On a side note, this is still the best ESC I have ever owned (all Novak since my first N-4) ….and the 13.5 SS is pure silky smooth!!
Double Quattro is offline   Reply With Quote
Old 06-05-2007, 08:30 AM   #93
OK, here's the short version:
Anyone having any trouble with the GTB staying in Brushed mode or working intermittently when using 2 motor plugs like Deans plugs?
Like I said, it hasn't been a problem when the ESC is direct soldered to the Brushed or Brushless motor.
Old 06-05-2007, 08:33 AM   #94
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
Maybe there was a cold joint or something.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 06-05-2007, 08:35 AM   #95
I'm pretty sure I had solid points. Thanks for the reply.
Old 07-29-2007, 12:36 PM   #96
rmdhawaii's Avatar
Since this has been out for a while now, I was wondering if anyone has any feedback on this system - especially from those that were running 2.4Mhz with the non-spectrum GTB. Can you tell the difference?
Thanks!
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 07-30-2007, 03:09 PM   #97
rmdhawaii's Avatar
ttt
Old 11-29-2008, 07:35 PM   #98
KoE
KoE's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to KoE
Default anyone with combo GTB SS-M8-Spektrum-Hacker ?
would you mind referring to this post and help me solve it
i've re-bind tx/rx..problem solved! :-)
Yo!
KoE is offline   Reply With Quote
spectrum rx and speed control JGLracing R/C Items: For Sale/Trade 0 07-12-2008 04:47 AM
Differences between o.s speed .21 v-spec speed alum and magnesium. Hans_Andersson Nitro Off-Road 11 06-23-2008 06:02 PM
Novak GTB Brushless 4 cell speed spectrum speed controller. jland R/C Items: For Sale/Trade 2 10-21-2007 02:37 PM
AIRTRONICS M11 W/SPECTRUM AND 2 SPECTRUM RECEIVERS burm R/C Items: For Sale/Trade 10 03-05-2006 01:28 PM
ft/t4, speed control, servos, motors batteries,spectrum system, etc. johnny boy R/C Items: For Sale/Trade 24 12-07-2005 09:18 PM
