Brushless motor connections >
Old 03-29-2007, 08:58 PM
Iceracer's Avatar
Default Brushless motor connections
How do you swap brushless and brush motors on your brushless esc? Do you resolder? Modified deans to 3 pole? Any suggestions?
Iceracer is offline
Old 03-29-2007, 09:07 PM
I use these
http://www2.towerhobbies.com/cgi-bin...&I=LXJPY4&P=ML
Spoook is offline
Old 03-29-2007, 09:48 PM
Iceracer's Avatar
Originally Posted by Spoook
Do you solder short leads to the motors with these on them, or do you solder a female connector to the actual motor tab?
Iceracer is offline
Old 03-30-2007, 12:00 AM
I put a wire on the motor tab and a female connector on the other end.
Spoook is offline
Old 03-30-2007, 10:54 AM
James35's Avatar
Here you go. Custom 3 pin Deans:
http://www.rctech.net/forum/showthre...ighlight=deans
James35 is offline
Old 03-30-2007, 11:08 AM
Iceracer's Avatar
Originally Posted by James35
Thanks James. I tried searching this topic, but nothing was coming up.
Iceracer is offline
