Old 11-16-2002, 09:19 AM   #346
Airplane ESC with reverse??
Just think about that for a moment, airplane esc w/ reverse..........
psychofactor is offline   Reply With Quote
Old 11-17-2002, 02:57 AM   #347
Default Marvi, thats a good joke...
we need one of those once in awhile. Some here get way too serious. Bugs bunny had air brakes?
Nightbreed is offline   Reply With Quote
Old 11-17-2002, 06:04 AM   #348
lem2's Avatar
Default help
hi!!!
where can I get machine screws for the microRS4??
the ones that came with the kit are tapping screws.
I need the machine screws for the jet motor pod, it does not have any screw in the packet.
what size are these screws??
thanks
is there an online store where I can get them?
lem2 is offline   Reply With Quote
Old 11-17-2002, 07:30 AM   #349
Trader Rating: 69 (100%+)
sorry to be off topic but this may be funnier than the plane esc w/reverse thing
http://ww2.infotrade.com.au/insanitytest.htm
back to topic: lem2, replied to your query in the other thread. hope to see your micro in action soon ive seen your pro3 and i think your micro will be as cool looking as that
marvi is offline   Reply With Quote
Old 11-19-2002, 01:36 PM   #350
Send a message via AIM to genxhobbies
What about the Novak spy?? It's much better than the TO flash.
genxhobbies is offline   Reply With Quote
Old 11-27-2002, 04:51 AM   #351
Default Need help with my Micro!
Any suggestions on how to first charge my Team Orion 7.2 volt? What amp should I charge it for the first time and ect?
Any one recommend deans Micro conectors?
Should I file a flat spot the shaft of my my Micro elite mod to keep the pinion gear from falling off?
Any good clean ideas on how to make a belt tentioner?
Are the aluminum upper arms any good to buy?
Did anyone like the bump steer plate by HPI?
Its almost complete, I'll post some pics when I done.
Old 11-27-2002, 09:32 AM   #352
I'm not a battery genius, so I don't know what to tell you about the orion batt. I charge mine at 1-1.5 a with a delta peak of 10mv.
The micro dean's are great, we just got some more in today.
Yes, file a small flat spot on the motor for the pinion to bite into.
I saw pics of a homemade belt tensioner somwhere, but I can't seem to find it. Try a search on the forums at:
your micro
I have yet to see any reason to buy aluminum upper arms.
Are you talking about the HPI tie-rod set??? That's a great product, it should have been included with the kit, those steering racks suck.
Old 11-28-2002, 02:38 AM   #353
GTO2's Avatar
R/C Tech Charter Subscriber
Default Re: Need help with my Micro!
I do 3 cycles of charge-discharge at 1A-3A respectively.
I use ultra deans ( normal size)
The micro elite is a strong motor, shouldn't have used the plastic pinion. Go for metal ones, as recommended by TO.
Nope, for me I even take them out. I found it much smoother.
GTO2 is offline   Reply With Quote
Old 11-29-2002, 01:47 AM   #354
Default more questions
what is some good flexible wire? I like Wet Noodle by Deans, but I can't get it in a smaller gauge.
Also with the medal pinions do I need to file a groove on the motor shaft?
Old 11-29-2002, 06:22 AM   #355
You don't have to but, it couldn't hurt only help. I would recommend it.
Old 11-30-2002, 07:00 AM   #356
GTO2's Avatar
Default Re: more questions
I'm not sure if using the noodle is a bit overkill...anyway I use GS, same gauge
Nay, you don't need to file anything on the shaft. The Team Orion Metal gear comes with an Allen wrench to tighten the set screw.
Old 11-30-2002, 07:17 AM   #357
Durrrr!!
Of course it comes with a Set screw Other wise it wouldn't stay on at all.
The Flat spot on the shaft will give a more secure mounting grip on the shaft and will prevent it from spinning which in turn cause the set screw to loosen over time.
I did it I recommend it.
On these little motors granted it don't have to be done but why not. Not like it's a hard thing to do.
Old 11-30-2002, 07:41 AM   #358
GTO2's Avatar
never had a metal gear spun out due to (loose??) set screw on a TO mod before....anyway I suppose groove would be better if u have spare time to do it.
Old 11-30-2002, 07:52 AM   #359
GTO, I was just bustin balls don't take it to heart.
Like I said on these little motors I don't think it makes much of a difference but, it can only help. Takes all of 3 seconds to grind a little flat spot so why not YA know what I mean.
Old 11-30-2002, 08:03 AM   #360
GTO2's Avatar
no man, I'm cool...
just sharing my experience...thats all. Yeah, I know what u mean...that's cool too.
downsizing! (micro-t, alum micro desert, fx10, t-spec) superhornetrace R/C Items: For Sale/Trade 20 06-20-2008 10:14 PM
FS: LRP Quantum Micro (w/ reverse) and Team Orion Micro Big Block WeatherB R/C Items: For Sale/Trade 1 06-26-2005 10:19 AM
selling kinwald xxx,team B3, custom hpi micro and 540 hybrid micro conversion, cheap romster R/C Items: For Sale/Trade 15 09-18-2003 04:32 PM
Team Orion Micro Elite Modified Motor for Micro RS4 Supra66 R/C Items: For Sale/Trade 1 12-02-2002 05:43 PM
MICRO RS4, MICRO RS4 HOPUPS, XXXS PARTS, INTEGY 16x5, MOTORS, TIRES HarshGuy R/C Items: For Sale/Trade 0 03-10-2002 10:06 AM
