Old 11-13-2002, 05:59 PM   #331
lem2's Avatar
Default Thanks
Originally posted by psychofactor
Any ESC will work as long as you can get it to fit. JUst a matter of how critical you are when it comes to your setups.
As far as the Ti Antenna I never heard of it.
I just wanted to be sure, I have an extra one hanging around, and the voltag rating is from 6cell to 7cell,
One more Ignoramous Question-will it still work if i only use 5 cell?
thanks
lem
lem2 is offline   Reply With Quote
Old 11-13-2002, 06:40 PM   #332
GTO2's Avatar
R/C Tech Charter Subscriber
Default Re: question again
Actually I think the Explorer would be an overkill. And yes, the size is also huge compare to micro chassis, not to mention the weight. It will work though but if the weight is too much wouldn't you think it will be an extra load for the motor as well?
The Ti Antenna looks cool with the short length and looks and all, but not advisable for competition. Probably because of the length, they are more prone to interference/glitches. Check it out at HPI web. I use a Deans micro antenna (actually for plane) a bit heavy because of the anchoring nuts but so far no intf/glitch.
Originally posted by lem2
hello, one of the micro forums said that the
NOVAK explorer II
is not compatible with the microRS4?
is it just becaus of the size? or it will not work?
help? (so i really have to buy a new esc?)
and has anybody used the Ti Antenna by HPI?
any feedback??
GTO2 is offline   Reply With Quote
Old 11-13-2002, 09:30 PM   #333
Im2lazy's Avatar
posted by lem2
Should be fine.
Im2lazy is offline   Reply With Quote
Old 11-14-2002, 03:31 AM   #334
Default Would a...
Ko Propo mini fet servo PDS-947 be any good for my micro? Would that servo be considered the best one on the market? Price is not an issue. Would I have trouble using a fet servo with my GM 3r speedo or would I need a higher end speedo for it to work well?
Nightbreed is offline   Reply With Quote
Old 11-14-2002, 05:16 AM   #335
GTO2's Avatar
that would be one of the best mini servo. Actually was meant for 1/12 and F1. Not sure abt the GM3R thing, I suppose speedo have much to do with the motor spec instead of servos (?)
Old 11-14-2002, 08:55 PM   #336
Im2lazy's Avatar
posted by nightbreed
Ko Propo mini fet servo PDS-947 be any good for my micro? Price is not an issue... my GM 3r speedo
The speedo has as much or more to do with the performance of your vehicle, so why don't you get a new one as well? But as GTO2 said, that would be a great servo for your car.
That doesn't mean much from me as I own a Team orion Flash esc... I'm looking at a GM or an LRP. I think I'm gonna get the LRP quantum though.
Old 11-15-2002, 02:01 AM   #337
Default Well, I want...
a speedo with reverse. I already have a GMV12 worlds, but no reverse. I don't want to buy a GMV12 reverse. Too much $$$ I just hope it works ok.
Old 11-15-2002, 04:29 AM   #338
Im2lazy's Avatar
I know what you mean... I think I saw that esc going for about 160-180 dollars .
Just be glad you didn't get a Team Orion esc...
Old 11-15-2002, 04:40 AM   #339
GTO2's Avatar
I'm using Quantum Reverse...reasonably small and fair specs.
Anyone tried plane's ESC? They are pretty small, cheap and light weight...not sure if it works with gun type controller though
Old 11-15-2002, 06:00 AM   #340
Trader Rating: 69 (100%+)
i think airplane type esc's will work. i almost bought one for my micro but i couldnt find on with brakes or reverse.
marvi is offline   Reply With Quote
Old 11-15-2002, 08:04 AM   #341
GTO2's Avatar
never heard plane ESC with Reverse before...that's new...
Old 11-16-2002, 02:43 AM   #342
Default Im2lazy...
what was wrong with the Team Orion speedo? It looks like it has a low center of gravity anyway. I had thought about getting one.
Old 11-16-2002, 06:59 AM   #343
Im2lazy's Avatar
There are a few with brake (which are not very strong brakes), but having reverse on an airplane would be the funniest (and stupidest thing) a manufacturer could do for their airplane esc.
Old 11-16-2002, 07:09 AM   #344
Im2lazy's Avatar
Default Re: Im2lazy...
Apparently, you haven't been exposed to their horrible tendencies. It is not very smooth. It has durability issues. And it makes the most wonderful ( ) humming noises of any esc I've seen. I've had to solder the switch to the esc so many times...
The thing is waterproof, while handy (I've been known to take advantage of this feature often), but the esc is like a solid sealant thing with wires coming out of it. The wires exit the case rigidly, so if you bent the wire, it would stay bent. My switch wire broke at the base, but you can't take it apart to fix it well. I had to dig out some of the case to be able to find the wire and solder it back on.
Don't get it. Get a good esc.
Old 11-16-2002, 08:13 AM   #345
no wonder i couldnt find an airplane esc w/rev
downsizing! (micro-t, alum micro desert, fx10, t-spec) superhornetrace R/C Items: For Sale/Trade 20 06-20-2008 10:14 PM
FS: LRP Quantum Micro (w/ reverse) and Team Orion Micro Big Block WeatherB R/C Items: For Sale/Trade 1 06-26-2005 10:19 AM
selling kinwald xxx,team B3, custom hpi micro and 540 hybrid micro conversion, cheap romster R/C Items: For Sale/Trade 15 09-18-2003 04:32 PM
Team Orion Micro Elite Modified Motor for Micro RS4 Supra66 R/C Items: For Sale/Trade 1 12-02-2002 05:43 PM
MICRO RS4, MICRO RS4 HOPUPS, XXXS PARTS, INTEGY 16x5, MOTORS, TIRES HarshGuy R/C Items: For Sale/Trade 0 03-10-2002 10:06 AM
