Old 11-11-2001, 09:47 PM   #151
TFR
TFR's Avatar
err.....still dont work....
how do you charge your batter?
what holder do you use?
I use a holder like this to charge my 4 1100mah cells
OO
OO Top view.....
is this why, because that holder gets pretty hot....
TFR is offline   Reply With Quote
Old 11-11-2001, 09:51 PM   #152
HarshGuy's Avatar
I changed the plugs to deans male plugs on the battery side so I can clip the charge leads on to it. I can charge them on either my T35 or Integy 16x5 with the same settings.
BTW, finally took some pictures of it, Without Body
With Body
HarshGuy is offline   Reply With Quote
Old 11-11-2001, 10:03 PM   #153
TFR
TFR's Avatar
does it help tho?
using the deans plug?
r u using
OO
OO this holder as well?
Old 11-11-2001, 10:05 PM   #154
TFR
TFR's Avatar
BTW, nice car...
Old 11-11-2001, 10:10 PM   #155
TFR
TFR's Avatar
custom exhaurst and antenna.
Old 11-12-2001, 07:23 AM   #156
HarshGuy's Avatar
I'm using the battery holder that came with the kit (the non 4-AA holder). I cut the tabs off so that I could mount the batteries sidways i.e. parallell to the chassis. That exhaust & antenna look cool! What did you do with the antenna?
Old 11-12-2001, 07:48 PM   #157
TFR
TFR's Avatar
Oh...
Thank You!!....Those antenna and the exhaurst are from 1/24 scale static models...
Old 11-14-2001, 08:26 PM   #158
TFR
TFR's Avatar
damn, i m giving up on my 1100mah batteries now...
any recommandation on what brand of batteries i should buy....??
Old 11-15-2001, 08:52 AM   #159
HarshGuy's Avatar
The 1100MAH ones that I've been using seem to work fine ...they're the Team Orion Micro packs.
Old 11-15-2001, 02:24 PM   #160
TFR
TFR's Avatar
how much is it??
HPI also have a batt pack right??
Old 11-15-2001, 08:47 PM   #161
TFR
TFR's Avatar
Sorry guys, but one more question...
I seen people use AA and AAA batteries...but i also notice somebody is using some 2/3a batteries....what are those...and how many cell would work good on a stock motor??
Are the 2/3a cells better...??
or should i just get some Panasonic 1600mah nimh batteries??
Old 11-15-2001, 10:48 PM   #162
dtm
dtm's Avatar
Send a message via ICQ to dtm
If I read you right, the 2/3a batteries that you are talking about are the 600mah NiCd batteries used for the recievers of gas cars (They now come in higher capacities and Nimh). They are heavier than the AAA cells but I'm using them because they can take a lot more abuse when charging (because they are Nicd). I use 1.5A. 6 cells will run really nicely on the micro!
dtm is offline   Reply With Quote
Old 11-15-2001, 10:51 PM   #163
whatever you guys do, don't use AA rechargeables because they have lower voltage
was ist los? is offline   Reply With Quote
Old 11-16-2001, 07:20 AM   #164
zxt
zxt's Avatar
Default okay okay
I just got my Micro today...I got it used...but in very good condition because the guy had it for only 2 months.
Lots of questions...
So I'm not supposed to use AA rechargeables? But if I'm going to use an Alkaline that would be expensive because only after an hour (am I right?) the battery is dead and I need to buy again...
What battery packs alternative I can use? How do I charge them? Is there a special charger for this packs?
TFR: HPI has batt packs specially for micro....but I got a bigger problem...seems like that its not available here...
any more tips?
zxt is offline   Reply With Quote
Old 11-16-2001, 07:38 AM   #165
HarshGuy's Avatar
I'm using the team Orion 5 cell 1100 MAH pack, retails for $38.99 ...works great, I've charged it twice (discharging it first all the way with a single 2 amp bulb) and both times charged at 1 amp charges up to a little over 1100 MAH in a little over an hour.
downsizing! (micro-t, alum micro desert, fx10, t-spec) superhornetrace R/C Items: For Sale/Trade 20 06-20-2008 10:14 PM
FS: LRP Quantum Micro (w/ reverse) and Team Orion Micro Big Block WeatherB R/C Items: For Sale/Trade 1 06-26-2005 10:19 AM
selling kinwald xxx,team B3, custom hpi micro and 540 hybrid micro conversion, cheap romster R/C Items: For Sale/Trade 15 09-18-2003 04:32 PM
Team Orion Micro Elite Modified Motor for Micro RS4 Supra66 R/C Items: For Sale/Trade 1 12-02-2002 05:43 PM
MICRO RS4, MICRO RS4 HOPUPS, XXXS PARTS, INTEGY 16x5, MOTORS, TIRES HarshGuy R/C Items: For Sale/Trade 0 03-10-2002 10:06 AM
