Good FM Receiver?? >
Good FM Receiver??
Good FM Receiver??
Old 03-24-2007, 05:17 PM
AWK
AWK's Avatar
Default Good FM Receiver??
I need to try a different FM receiver in my TA05 because ever since I got these Novak XXLs, they have a constant glitch in the car. My current setup is the Novak XXL, Futaba S9550 servo, Checkpoint 19t, Novak GTX, and Futaba FM 75mHz radio system.
I have tried 2 different XXLs and they both give me the same issue. I have even installed additional motor capacitors, and nothing. A new receiver might do the trick so I am looking for some good models that would work with my setup.
AWK is offline
Old 03-24-2007, 07:01 PM
k_bojar's Avatar
Trader Rating: 30 (100%+)
did you try a different crystal?? the problem may be there instead of the receivers
also, give another/different esc a try
I've seen many problems lying in the crystals instead of the actual receivers
k_bojar is offline
Old 03-24-2007, 07:34 PM
AWK
AWK's Avatar
Yeah I forgot to mention I tried 3 different sets of crystals. I also tried another esc but that didn't seem to help.
AWK is offline
Old 03-24-2007, 07:40 PM
UN4RACING's Avatar
Trader Rating: 22 (100%+)
What kind of radio are you using? I use a R-200 rec. by JR. Never ever had any trouble and its about 9 or 10 years old.
UN4RACING is offline
Old 03-24-2007, 07:47 PM
AWK
AWK's Avatar
I have a Futaba Magnum 3PDF radio FM 75mHz system
AWK is offline
Old 03-24-2007, 08:42 PM
adamge's Avatar
Sombra Labs Shadow 3
adamge is offline
Old 03-24-2007, 10:33 PM
k_bojar's Avatar
Does it glitch when its not mounted in the chassis?? Maybe you need to move it to another location on the chassis?
Which chassis are you running? Sometimes receiver don't like to be against the carbon of the chassis, or the antenna is touching something..
I'd try moving it before shelling out the $$ for a new receiver..
k_bojar is offline
Old 03-24-2007, 10:50 PM
AWK
AWK's Avatar
Well it isn't a big deal really. If I buy a new one and it works better, than I will sell the other two. If not, I will just return it.
I can only really mount it where it is now because of the layout of the TA05 tub and the length of the GTX wires.
AWK is offline
Old 03-24-2007, 11:05 PM
i had the same problem,i also have a ta05,,mount the reciever on top of the servo, away from the motor.if its next to the motor it starts to glitch.
LAPDOG is offline
Old 03-25-2007, 06:41 AM
k_bojar's Avatar
That's why I was asking...some chassis' have different locations where the receivers need to be mounted because of proximity to the motor and/or ESC
Try that before you buy a new esc...selling the older ones won't net you anywhere close to what you paid for the 1 new one...
k_bojar is offline
Old 04-05-2007, 12:26 PM
XrayMichaelT2's Avatar
I have a XXL in my T2 with a Futaba9451 and a SuperSport 5800 setup and have never had a single glitch ever. I also like the JR RS300 synthesized reciever.
XrayMichaelT2 is offline
