Old 04-01-2003, 08:24 AM   #16
omalley's Avatar
Send a message via AIM to omalley
yep the integy does come with a one page print out, with some pictures but nothing really meaty or detailed. ill check out the hudy site.
omalley is offline   Reply With Quote
Old 04-01-2003, 09:34 AM   #17
popsracer's Avatar
Default Integy Setup Tool
Guys;
The set-up station made thing MUCH easier (and accurate) when adjusting my Nitro cars. I like the Dead on Toe measurement as Toe F & R has a big impact on handling.
Probably my useful tool is my Integy Laser Tweak Station. With a un-tweaked chassis my Cars handle more consistantly and it's easier to lay down the Power in my Nitro Cars because the Cars drive straight. Both tools were some of my best investments for racing.
popsracer is offline   Reply With Quote
Old 04-01-2003, 10:01 AM   #18
RCBuddha's Avatar
Trader Rating: 35 (100%+)
I'm a firm believer in using the guages on a setup board. After "eyeballing" things for years, i broke down and bought a set of Integy Guages. I have been very pleased with them; as they really give a more equal handling.
My only other recommendation is to get a tire balancer and a MIP tweak station, which will make your car perfectly balanced.
Buddha
RCBuddha is offline   Reply With Quote
Old 04-01-2003, 10:32 AM   #19
Set-up board and station--- Very important for racers....
Tweak station---- ehhhh, if you got the money go ahead, otherwise do it old skool!!
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 04-02-2003, 12:00 AM   #20
dsrbltoys's Avatar
These setup stations are nice. I have had both the hudy and the integy. I sold my hudy after our club had used it for about a year and it got VERY scratched. The integy is metal and can be repainted if needed. The slide plate for the toe is still the same way though. The part numbers above are a little misleading. The c22305m is actually just the nuts only. You can also use these on the hudy, they work great. With the stock nuts they are usually a nylock type nut. These integy nuts are knurled nuts (on the outside) that thread onto the axle, without any locking device. Since the back of either of these stations do not have any place for a hex to fit, the hex simply spins when trying to use the lock nuts. The other nice feature from integy is the carry case. There is also enough room in it to slide my MIP tweek station into it. The integy lazer tweek station I tried seemed to have a slow (inaccurate) bubble guage, but the bearings I think are better. As for whether you need any of these, I think that is something a good track would have there for customers to use. A serious racer can benifit most by being able to accuratly recreate the same setup car to car, and even more so if the car is to be raced at different tracks. good luck. hope that helps.
dsrbltoys is offline   Reply With Quote
Old 04-02-2003, 12:07 AM   #21
davioh's Avatar
does anyone know the price for one of the hudy's? i might get one if it's cheap
davioh is offline   Reply With Quote
Old 04-02-2003, 12:22 AM   #22
You are in Hong Kong, isn't Mong Kok suppose to be the rc parts central?
elnitro is offline   Reply With Quote
Old 04-02-2003, 11:04 AM   #23
rc-zombies's Avatar
Hudy's are not cheap... you can get 2 integy setup station for the price of 1 Hudy. or better yet..for the price of a Hudy you can get the Integy setup station along with the Integy Laser tweak station.
Personnally I do not like the HUDY...'coz of the clear acrylic used..the markings are hard to see and also suseptible to scratches. The Integy marking are easily readable, more durable, plus you get a padded case. Hudy does not have a case.
Old 04-02-2003, 11:08 AM   #24
rc-zombies's Avatar
Originally posted by dsrbltoys
..... The integy lazer tweek station I tried seemed to have a slow (inaccurate) bubble guage, but the bearings I think are better. ....
yes it does have a very slow bubble..
I use a bubble that I purchase from HomeDepot for under a buck.
the Round leveling bubble works the best... you can adjust left/right, front/back all at one time...
Old 04-02-2003, 07:29 PM   #25
popsracer's Avatar
Default INTEGY Laser Tweak Station
I too used a second level with mine. INTEGY will send owners of the Laser Tweak a NEW Bubble vile FREE of charge to correct the problem.
Just visit their website and send an E-mail to customer support. Took a couple of days to get mine and it works much better now.
Old 04-03-2003, 01:51 AM   #26
Why are you using the bubble to check the tweak on the Integy? Why not use the laser?
Sydewynder is offline   Reply With Quote
Old 04-03-2003, 08:37 AM   #27
popsracer's Avatar
The Bubble is used to level the unit on the table (but you knew that) and I prefer not to carry a seperate level in my box for this. The Laser works GREAT so checking/setting Tweak, much easier in my opinion than a bubble.
Old 04-03-2003, 09:05 AM   #28
rc-zombies's Avatar
Default Re: INTEGY Laser Tweak Station
The new bubble vile they sent me was still slow but better than the original...
I still use the round level that I got from Homedepot..
Old 09-30-2008, 05:40 AM   #29
Renault_Tech's Avatar
Sorry to dig up an old thread but i just got mine today and the axle nuts are too shallow for my Kyosho. Do i have to buy the metric ones??
Renault_Tech is offline   Reply With Quote
Old 09-30-2008, 05:59 AM   #30
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Yes. Or you can use the wheels nuts.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
***Integy Tire Truer/Hudy 1/10th setup gauges/Integy Charger F/S*** HarKonnenD R/C Items: For Sale/Trade 40 09-25-2008 10:17 PM
Team Integy Setup Station 2 w Case and setup board - complete olhipster1 R/C Items: For Sale/Trade 4 11-02-2007 08:21 PM
WTB Unity Setup tool nathan g R/C Items: Wanted to Buy 0 01-12-2006 04:21 PM
PMB Setup Tool elmar66 Nitro On-Road 3 05-15-2004 09:37 PM
14 pc. INTEGY TOOL SET (not a month old) Ko Racer R/C Items: For Sale/Trade 4 06-27-2003 12:38 PM
