Swap Motor Bushings for Bearings
We sell a tool on www.teambrood.com that does it without damaging your bearing or bushing.....or the can/endbell.
Later EddieO
Later EddieO
Originally Posted by nexxus
Keep in mind doing this makes the motor ILLEGAL for sanctioned events.
Later EddieO
Later EddieO
I have been interested in putting bearings in a stock motor for awhile, but never knew exactly what it entailed, I took apart an old stock motor, the bushing in the endbell came out easy, but I couldn't get the one out of the can to break free.
Jake, just buy a 19T motor...... those come with bearings.
Not sure where you are racing, but if your track follows ROAR rules then you CAN NOT do that.
I would make sure and check with the other racers and the race director to make sure you can run that motor if you do change the bushings to bearings.
Originally Posted by Jake S
... but I couldn't get the one out of the can to break free.
Sorry on our site, should be fixed now...there was some server problems...
The reason they sometimes are super tight is because they typically are cooled before install, so when they heat up, they get a little bigger, so they have a nice tight fit. Our tool basically forces them out without damaging them or your motor....
As for the bearings, we sell those too....on the site in pairs or single. Ours are the same ones you get in the motors, not a cheap bearing that will fall apart when spinning 30k+ rpm...
Later EddieO
Later EddieO
