spektrum antenna >
spektrum antenna
spektrum antenna
Old 03-19-2007, 08:14 PM
PoLsKiE's Avatar
Trader Rating: 30 (100%+)
Default spektrum antenna
i have spektrum pro on my airtronics m8 and it tipped over on the module side and cracked the antenna tab on the inside only 1 tab and it is really loose and comes out a bit but my question i this i bought this spektrum pro system new in last month on ebay it says they want a reciept for proof of purchase what do i do now i dont have a reciept exept for a invoice if that will work if not do they sell the antenna itself? i can replace it let me know guys i need help thanks
PoLsKiE is offline
Old 03-19-2007, 09:09 PM
RCGaryK's Avatar
A receipt is necessary for any warantee work. If it's bought off of eBay, it's nearly impossible to prove that it was NIB or that you are the first owner (warantee is not transferrable). The antenna is not available seperately for purchase and the modules are not user-serviceable
RCGaryK is offline
Old 03-19-2007, 09:11 PM
PoLsKiE's Avatar
so technically im screwed?
PoLsKiE is offline
Old 03-19-2007, 09:13 PM
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
yeh kinda seems that way
unless u can fix it
BlackedOutREVO is offline
Old 03-19-2007, 09:20 PM
PoLsKiE's Avatar
i mean its fully funtional no problem its just its loose andyou can pull it somewhat out do they do servicing...new or used for a cost?
PoLsKiE is offline
Old 03-19-2007, 09:31 PM
idk, i know some brands do that for a cost.... but idk for shure
RCGaryK's Avatar
You can have it serviced for a fee.
RCGaryK is offline
Old 03-19-2007, 09:33 PM
PoLsKiE's Avatar
any special procedure to do before i send it in or somthing
PoLsKiE is offline
Old 03-19-2007, 09:35 PM
im pretty shure just send it in
Old 03-19-2007, 09:57 PM
her is what idid to mine when it happend to me let me know if you would like to do it ill tell you how real easy
jeremiahdenton is offline
Old 03-19-2007, 10:28 PM
arr see car's Avatar
Location: West Ozzie living in Merrigum...Shepparton...Victoria
I to have done the same to mine and my brothers . Easy to do and you dont have to worry about the antenna being knocked and you can lye the controller down with out any problems.
I would be doing this mod. Solve all your problems.
arr see car is offline
Old 03-20-2007, 05:53 AM
Trader Rating: 38 (100%+)
I did that same thing with my helios radio and spektrum TX. Might as well just do the mod, no need to send it back just to fix a tab.
mattnin is offline
Old 03-20-2007, 06:39 AM
StoneMan's Avatar
I have done the same thing to. All I did to fix is open up the case, the tab is probably inside. I pulled the antenae out a little, CA glued the tab back on
LET IT DRY and pushed it back in. It works fine and still pivots.
StoneMan is offline
Old 03-20-2007, 08:32 AM
The same thing happened to my M11. I was told by Spektrum that I had to send the module in for service with turnaround time being about 10 business days. This wasn't acceptable at the time so I opened the module and came up with a simple, low-tech temporary solution. I just wedged a small piece of paper towel into the barrel that supports the antenna, which provides enough resistance that the antenna stays vertical. I've gotten so used to it that it has become a permanent fix. I will eventually relocate the antenna from the Spektrum module to the original antenna location on the M11 which should provide much better durability.
Hope this helps, Pete
Pete Thomas is offline
Old 03-20-2007, 09:29 AM
bvoltz's Avatar
Trader Rating: 44 (100%+)
I just sent in my Pro RX for a little service...
Goto this page: http://www.horizonhobby.com/Support/...t/Default.aspx
Open and print the "Service Center Repair Request Form" PDF file.
Fill it out and send it in.
1 week in total shipping time
1 week for service
You should have it back in two weeks...
Hope this helps...
bvoltz is offline
