Old 03-19-2007, 03:34 PM   #1
ADDMAN's Avatar
Send a message via MSN to ADDMAN
modifed motor help
i have got 2 BRM's 12X2 and V2 11X2 and others but the three i have mentioned have all stopped working at full potential i have changed brushed skimmed and cleaned them they work for a bit then if they stop they wont start again they need a push and they get very hot very quickly and the gearing is fine and there is no significant internal resistance the speedo is fine (novak GT7) please help
ADDMAN is offline   Reply With Quote
Old 03-19-2007, 05:44 PM   #2
Z.Hallett's Avatar
Send a message via AIM to Z.Hallett
if they need a push to get started it sounds like either your gear mesh is too tight or you have a hung brush. check those first.
-Zac
Z.Hallett is offline   Reply With Quote
Old 03-19-2007, 05:47 PM   #3
ADDMAN's Avatar
whats a hung brush and its not the gearing cos it has the same problem out of the car
Old 03-19-2007, 05:59 PM   #4
Z.Hallett's Avatar
a hung brush happens when the brush is cocked sideways in the hood, and the spring is too weak to force the brush to make contact with the comm. clean out the brush hoods and put on new springs.
-Zac
Old 03-19-2007, 06:03 PM   #5
ADDMAN's Avatar
will that explain why im getting small sparks coming from where the brush is in contact with the comm
Old 03-19-2007, 06:10 PM   #6
Z.Hallett's Avatar
small sparks are ok, but if the sparks are rather large this means the edges of brush are dragging in the separations of the comm plates.
-Zac
Old 03-19-2007, 06:12 PM   #7
ADDMAN's Avatar
they are only small but will having a hung brush cause performance fluctuations cos i can be going slow then all of a sudden i get the full power of an 11X1 when ur not expecting it
Old 03-19-2007, 06:14 PM   #8
Z.Hallett's Avatar
check the windings for discoloration and possibly a loose winding. the hung brush would make for an 11X1 to feel like a 540 maubachi.
-Zac
Old 03-19-2007, 06:19 PM   #9
ADDMAN's Avatar
the armature is fine and there is not wobble of the brushes in the hood could the spring tension be the problem
Old 03-19-2007, 06:21 PM   #10
Z.Hallett's Avatar
too soft of a spring could make the brushes bounce alot and could possibly cause a lack of performance. you should be using a trinity purple on both the pos. and neg.
-Zac
Old 03-19-2007, 08:39 PM   #11
ADDMAN's Avatar
is it true you can run a stiffer spring on th +ve side to improve efficiency?
F/S-Mini Inferno ST 09 w/Modifed Motor, CVD's and more!!! YokomoMR4BX R/C Items: For Sale/Trade 43 10-20-2007 11:19 AM
F/S Novarossi Mugen Seiki X-12 3 ports modifed .12 engine for Touring car Solara R/C Items: For Sale/Trade 0 07-26-2007 10:06 AM
Times For Stock and Modifed Main events TSB Northwest Racers 26 05-07-2005 11:11 PM
JP Modifed P5, black case - purple head motoazure R/C Items: For Sale/Trade 0 10-11-2004 04:58 PM
Team Orion Core Modifed Motors For Sale olewarrior R/C Items: For Sale/Trade 7 02-12-2003 08:58 PM
