Old 03-16-2007, 08:35 PM   #1
nikkiesteban's Avatar
Send a message via Yahoo to nikkiesteban
Default how to identify futaba AM rx
guys i have two RX from futaba. 1x 27mhz and 1x 29mhz both AM's.
and i removed them from their respective cases and after cleaning i dont remember what is the 29 rx and 27 rx.. can u help me please. can i identify the rx of 27mhz by looking into the chip in the RX. it has code like FP8196R............ i wud like to ask favor can you take a look inside your RX AM 27mhz and see if what code is written.. please..
nikkiesteban is offline   Reply With Quote
Old 03-16-2007, 11:18 PM   #2
Registered User
I had a 27mhz in the garage and FP8196R is written on the chip .. but that doesn't mean everything since FP8196R is just the chip # and could be used between bands .. easiest thing to try would be to put a crystal in it, hooked it up and see if it works. Takes just a second.
Desolas is offline   Reply With Quote
Old 03-17-2007, 07:28 AM   #3
WC
WC's Avatar
Trader Rating: 28 (100%+)
Originally Posted by nikkiesteban
and i removed them from their respective cases and after cleaning i dont remember what is the 29 rx and 27 rx.. ..
what colour is your antenna wire? (assuming they're original, not changed)
All my RJ112s have got PURPLE wire for the 29s.
The 27s I think are black wire, white for the 40 or 75 I think.
www.PandaGFX.com
www.MelbRC.org
WC is offline   Reply With Quote
Old 03-17-2007, 07:30 AM   #4
WC
WC's Avatar
nup, a 29 RX will still work with a 27 xtal... at close range.
You'll need to range test it, say separate TX & RX by 100m or more.
Only there will the wrong band show up enough detuning to stop working.
www.PandaGFX.com
www.MelbRC.org
Old 03-17-2007, 06:23 PM   #5
i rewired them so i really cant tell.. if i take a look at the other side of the PCB it has a number written in it. like number 2 and the other rx is number 3. can u take a look at your AM rx and see if its number to or 3. thanks
Old 03-18-2007, 08:55 AM   #6
WC
WC's Avatar
I think the PCB & major chip on the board is identical between the RJ112s.
Some yrs back I had an elec engie look at these boards
trying to see if it was worth/possible to change their bands.
We were checking out 27, 29 & 75MHz from memory.
Difference between bands were only some of the "chokes"
(capacitors?) from memory, everything else on the board
is the same. But these components were not easily (retail)
available so it was a moot point anyways.
If you've changed their antennas, then rangetest is the best way to check.
When I rewire my RXes, I stick to purple for 29MHz etc etc.
www.PandaGFX.com
www.MelbRC.org
CAN SOMEONE PLEASE IDENTIFY THIS.... CCH1978 Electric On-Road 10 08-13-2008 09:41 AM
Can someone identify this? aERonAUtical96 Electric On-Road 19 04-17-2008 11:09 AM
Can anyone Identify these? TStorm Nitro Off-Road 5 03-04-2008 05:25 AM
Help me identify this F-1 Car Matman03 Electric On-Road 14 05-02-2005 12:42 PM
Can anyone Identify This old ESC? PLS! Blackwrench™ Electric On-Road 22 06-23-2004 05:34 AM
