Front One Way
Front One Way
What does the Front one way unit do? I have the Center one way on my tao4r but i dont know what the front one way does.
Thnx
Thnx
hayo...TA04R!
Thanks alot that really helped. thats an awsome site and explained pretty much everything accept one thing.
What will happen if you have both. a Front one way and a center one way???
Dual one-ways? I havent tried it yet, but will soon. However, I'm quite sure that there wont be much difference compared to a one-way diff. The only difference I can think of, is that the front belt are allowed to free wheel, thus there will be less drag-brake in the drive train. That'll probably gain a little preventing that the rear slides, when off throttle.
The center one-way is the easiest to start with, but the one-way diff will give most improvement.
Ill give that a try too. let me know how your goes.
have you seen the new front one way diff one piece. it just came out on the tao4 trf. i think ill wait for that to come out.
Dual one ways work great for stock racing front one ways are good for mod but i run no one ways in my 414 for mod and i run only a front one way in my 04ss for stock only because i have abroken center one way
but one ways are great
Chris; Sounds reasonably. I'll give it a try.
Re: Front One Way
Thnx
Thnx
Thanx for all the help with the one ways.
Im wondering if the low friction belt makes a big difference.?..
Yep, low friction belts do make a good improvement.
Do you think i should continue to put my $$$ into this tao4r or go and buy a TRF-MII?
Sry this has nothing to do with this question but i was wondering how much you think my TAO4R is worth?
Its upgraded with a carbon lower deck, center-oneway, Aluminum Steering Arms, Carbon Damper Stay Front and Rear. Ive had it for about 3 months.
I havent got a pic of it but im working on that.
What are you using the car for? Racing, bashing?
I dont know the TA04R. But it's not the car that wins races, it's the driver, including the ability to setup the car.
