Dumb Question - Mohawk Cut Line >
Old 03-14-2007, 04:52 PM
Trader Rating: 38 (100%+)
Default Dumb Question - Mohawk Cut Line
Are there two cut lines on the Mohawk body? There is a line that lines up with the rear bumper cut line (higher) and one that lines up with the front bumper cut line (lower). Which am I supposed to use?
or8ital is offline
Old 03-14-2007, 05:19 PM
MikeXray's Avatar
Trader Rating: 73 (100%+)
Depends on your tires, with rubber @63mm you can get away with the lower one, on foams I cut mine to the higher line so I don't rip up the rug.
MikeXray is offline
Old 03-14-2007, 05:21 PM
Cool thanks, its for carpet. There seems to be a big difference between the two. A little bigger then most. Thanks again.
or8ital is offline
Old 03-16-2007, 08:39 AM
In case someone else reads this it is the lower line. Not sure what the upper line is. I cut it at the lower line, have the body all the way down (resting on the front shock tower) and it ends up right at the top of the bottom chassis.
or8ital is offline
