Old 03-10-2007, 02:39 PM   #1
Send a message via AIM to Carpetracer92
Default 3pk problem help
like its werid becasue when i turn up it goes left and when i go down it turn right, So how can i do it to make it the opposite, please help
Check out Long Island Low N Slow
Garage= Slammed g37,Full Exhaust
Carpetracer92 is offline   Reply With Quote
Old 03-10-2007, 03:22 PM   #2
I do not have a 3PK but it sounds like your steering is reversed. If you have the manual look for servo reversing and go from there.
Good luck
Loren
llamont is offline   Reply With Quote
Old 03-10-2007, 03:26 PM   #3
StoneCrawler's Avatar
Not sure if I understand you question correctly, but if you mean it's steering in the opposite direction you are turning the wheel, then you can use the Servo Reverse function on your transmitter.
On the 3PK, I believe its "REV" on the menu, then select "NOR" OR "REV", for steering.
StoneCrawler is offline   Reply With Quote
ESC PROBLEM ghj1997 Electric Off-Road 13 06-04-2008 08:38 AM
Problem RaceANissan616 Nitro On-Road 20 07-23-2006 09:07 PM
KO PRO PO VSF-1 PROBLEM mazmo Australian Racing 4 07-24-2005 07:38 AM
New to R/C and I have a bit of a problem ZeeBMaN Rookie Zone 6 05-15-2003 05:08 AM
