3pk problem help
Originally Posted by TeamSkitz06
like its werid becasue when i turn up it goes left and when i go down it turn right, So how can i do it to make it the opposite, please help
Good luck
Loren
Not sure if I understand you question correctly, but if you mean it's steering in the opposite direction you are turning the wheel, then you can use the Servo Reverse function on your transmitter.
On the 3PK, I believe its "REV" on the menu, then select "NOR" OR "REV", for steering.
