offset?
Old 03-08-2007, 10:36 PM
PoLsKiE's Avatar
Trader Rating: 30 (100%+)
Default offset?
im running cs27 takeoffs does anyone know the offset they are....these are the preounted ones and does takeoff have a website cause i cant find it i tryed google sorry if its a dumb question
PoLsKiE is offline
Old 03-09-2007, 01:15 AM
RocketRacer's Avatar
they are 0 offset.
RocketRacer is offline
Old 03-09-2007, 01:21 AM
PoLsKiE's Avatar
ok thanks i was wondering cause im buying some flashy wheels now and dident want them to rub or somthing....and 1 more question if i go more offset or somthing would it make the wheels stick out more or stick in.... is there a plus offset and a negative offset? id would like to know just a bit
PoLsKiE is offline
Old 03-09-2007, 01:38 AM
+offset will make the wheels stick out and -offset will make the wheels sit mor under the body.
generally a +2offset will mean you should run a 200mm body instead of the 190mm body.
Old 03-09-2007, 01:40 AM
PoLsKiE's Avatar
i was figureing i should run mabey 1 or 2 offset cause i get a bit of a rubbing problem thanks soo much for the help
PoLsKiE is offline
Old 03-09-2007, 01:44 AM
you could also add spacers to the hub to increase the track width. that could also solve any rubbing problems.
Old 03-09-2007, 01:49 AM
PoLsKiE's Avatar
i forgot about that i can only run 24 mm tires cause of rubbing but now in that case i can do 26mm thanks
PoLsKiE is offline
