Old 03-07-2007, 05:09 PM   #1
TEM
TEM's Avatar
Default 3S lipo radio safe? have you tried it?
Has anyone out there put a 3S (3 cell series) lipo in their radio? Do you add anything in between or is the voltage (over 12v when charged) safe for the radio? The voltage meter never went past mid 11's with 8C nicad. What are they rated for?
TEM is offline   Reply With Quote
Old 03-07-2007, 05:20 PM   #2
kuzo's Avatar
Send a message via MSN to kuzo
I'm using them in 4 Spektrums with no issues and no regulator or anything. If you used 8 Alkaline batteries you'd hit around 12V anyway. I did ask the question before I risked it too but no problems.
kuzo is offline   Reply With Quote
Old 03-07-2007, 06:58 PM   #3
adamge's Avatar
I've used a Thunder Power 3s1320 lipo in my transmitters for the last year. It works fine. The benefits are no self discharge and lighter weight. The big downside is that if you leave the TX on, or it gets turned on in transportation, the battery is garbage (expensive garbage). I connect it in the battery tray area with a Deans Micro, and unplug the battery during transportation.
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 03-08-2007, 07:07 AM   #4
rampal's Avatar
Send a message via MSN to rampal
I have a 3000mah lipo from LRP on my M11, and it is absolutely amazing... It has been on for 10 hours and still well above 10v.... the only caution I always follow with Lipo is to chage them outside the radio and directly from the charger, not passing through the radio.
al
The Blue Armada: Tamiya TRF415MSXX, Tamiya TA05MS, Tamiya/Xenon TA05
Novak Brushless, Orion/Peak LiPo batteries, 5-cell
Sanwa M11 DSSS, KO Propo Servos
rampal is offline   Reply With Quote
Old 03-08-2007, 10:44 AM   #5
MrBlack's Avatar
u have using our Avionics 3S lipos in my radio for over a year now and it has worked flawless I re-peak it up every couple of weeks to get max signal strength.
ORI60005 SLPB 1250mAh 11.1v, 3S-1P
http://www.teamorion-avionics.com/Ba...Li-Po/1250mAh+
larger capacities can be used depending on radio.
TEAM ORION - AVIONICS - KYOSHO - KO PROPO - PEAK
"Racing is about the journey not the destination if it wasn't it would simply be called Arriving"
"The solution is people need to spend more of their efforts on promoting and finding more people to race with, rather then a personal quest to form a class that they can win at."
MrBlack is offline   Reply With Quote
Old 03-08-2007, 10:57 AM   #6
syndr0me's Avatar
Trader Rating: 32 (100%+)
Wow, that's cool. I've been trying to find a decent LiPo for my 3PK for a while, and they're all so hard to find, or expensive.
Anybody know where to get an extra connector that the Futaba radios use for their battery?
syndr0me is offline   Reply With Quote
Old 03-08-2007, 10:59 AM   #7
MrBlack's Avatar
I took a servo extension cable and hacked the plug if you canlt find a plug in stores.
Old 03-08-2007, 11:01 AM   #8
TEM
TEM's Avatar
I got a few kokam 3s1p 640mah I can parallel together; 2 of them would make 1280 which should be enough. I just found out last night they are too thick!; gonna have to cut the shrink and re-stack them to fit!.... Thanks everyone!
Old 03-08-2007, 11:12 AM   #9
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
same happened to me this past weekend. 2200mah 3s pack down the drain...been using the same 3s pack for over 3 years. its an pack used for electric flight, used it in my KO Mars R then switched it to the Helios.
When not in use, I'm going to disconnect the plug from the radio to the TX pack.
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 03-08-2007, 11:29 AM   #10
syndr0me's Avatar
I've gotten into the habit of putting my LiPo batteries in a Liposack for storage during the week. I guess I could add the extra step of doing the same with my transmitter pack.
MrBlack,
At what voltage would you want to pull that pack from your radio and charge it to ensure you don't discharge it too far?
Old 03-08-2007, 11:46 AM   #11
SlamMan's Avatar
So I can wire up just about any 11.1V Lipo in my 3PK as long as it will fit in the battery compartment?
Michael H
OnRoadColorado.com
Colorado On Road RC Club
SlamMan is offline   Reply With Quote
Old 03-08-2007, 11:46 AM   #12
rampal's Avatar
Originally Posted by syndr0me
MrBlack,
sorry to hijack MrBlack, but I usually use the 3.3V rule to be on the safe side.... 3S = 9.9v.... the radio has a 9V alarm, so still on the safe side....
....that's why I mention 10v on my first post....
Old 03-08-2007, 11:50 AM   #13
rampal's Avatar
yes... radio energy consumption are on the lower side... any 5C 11.1v pack can do the trick.... for emergencies I also have a 11.1v 1050mah GWS pack and it work perfectly....
Old 03-08-2007, 12:40 PM   #14
linger's Avatar
I use a 2.5Ah lipo in my 3PK. I had it on for 16 hours continuously and the battery still provided good voltage.
You can get a low voltage cutoff for about $6 to prevent an overdischarge condition. I have something similar on mine.
http://www.batteryspace.com/index.as...OD&ProdID=2776
I used to be a spitter, now I'm a swallower. I graduated.
linger is offline   Reply With Quote
Old 03-08-2007, 12:55 PM   #15
syndr0me's Avatar
Do you have a source for the battery that you used, or is it something you assembled on your own?
I was hoping to just get the VXR pack since it apparently includes a nice foam holster, but they have disappeared from the planet entirely.
HAKKO ESD Safe Soldering Station and ORION Advantage Carbon LiPo Charger. SWEET!! Ron Meloni R/C Items: For Sale/Trade 4 09-12-2008 12:08 PM
temporary AM radio setup for 1/8 nitro buggy......will I be safe?? pwnzor Radio and Electronics 5 07-06-2008 12:55 AM
temporary AM radio for 1/8 nitro buggy....will i be safe?? pwnzor Nitro Off-Road 49 06-30-2008 10:25 PM
futaba 3pm -fm radio with 2 recivers and venom fail safe for sale 95 $hiped milk R/C Items: For Sale/Trade 14 01-14-2008 07:02 AM
Ofna micro fail safe, jr z650m 650 servo, and rtr ofna radio set cappa R/C Items: For Sale/Trade 13 02-03-2005 11:35 PM
