Car cleaning and bearings. >
Old 03-07-2007, 04:48 AM
I have had my car about a year and have decided that it is probably time to strip the car down and give it a good clean. I built the car as per the instruction, and didn't do anything special with the bearings.
Whilst I have the car stripped down, what should I do to clean the bearings?
Cheers in advance
simon_allen is offline
Old 03-07-2007, 05:59 AM
Trader Rating: 32 (100%+)
Thoroughly clean out the bearing with either motor spray or nitro wash. RPM makes a bearing blaster that makes the process very easy, or you can also use a jewerly cleaner device (Indi Sparkle) filled with cleaner. These two items will make the cleaning very easy, but you can also just use a plastic bag or small cup filled with cleaner.
Once the bearings have been cleaned, spin them to "feel" if there is any grit left. If there is, repeat the process until all the grit is gone. Once there is no grit, lube the bearings with thin bearing oil and re-install.
After a year of use, you may find that some or all of the bearings may need to be replaced.
A. Rhodes is offline
Old 03-07-2007, 06:09 AM
UN4RACING's Avatar
Trader Rating: 22 (100%+)
I blow them out with an air hose, then I use an RPM bearing blaster and spray them out with motor cleaner. Then put some bearing oil in and if the bearing doesn't spin free, I replace the bearing. The oval thread has good info on bearing maintenance. Bearings that spin free equal lightning fast lap times. And more efficient run times. If your bearings are year old I would lean towards a complete bearing replacement and save the old ones as back ups.
There probably not going to be very good if you haven't kept them up at all.
Unless your running indoors? Then maybe. Try a lot of different stuff the bearings are very important.
UN4RACING is offline
Old 03-07-2007, 06:20 AM
My bearings are standard Tamiya ones and have a metal cover. Do I need to remove these covers to clean the inside? How do I get them off?
Does anyone have a web address of a good article on how to clean the bearings?
Old 03-07-2007, 06:24 AM
http://forum.teamxray.com/viewtopic.php?t=1315&start=18
thats just one of the many ways to do it.
MManson is offline
Old 03-07-2007, 07:12 AM
SlamMan's Avatar
Decent bearings can be had for a buck each. I just replace as needed.
SlamMan is offline
Old 03-07-2007, 07:29 AM
Ridge_Racer's Avatar
Sweet!!! I have been looking all over for that Sparkle thingy. I got one ordered
Ridge_Racer is offline
