Spektrum Micro help >
Spektrum Micro help
Spektrum Micro help
Old 03-07-2007, 04:38 AM
Default Spektrum Micro help
what connection does the spektrum micro use? the connections from my mamba and kopropo servo do not fit, can some please tell what will fit?
thanks
myk505 is offline
Old 03-07-2007, 05:14 AM
Capt.Micro's Avatar
It will fit, you just have to shave off the plastic edge of the plug that ensures correct polarity.
Capt.Micro is offline
Old 03-08-2007, 12:18 AM
the connection from my mamba does no have the bit on the side and it does not fit either. does anyone know what type of connection i need?
myk505 is offline
Old 03-08-2007, 07:17 AM
rampal's Avatar
It is an standard futaba or "J" connector. Perhaps the sanwa/airtronics "Z" connectors fits better, due its slighty smaller width. Nevertheless, I have some Spektrum pro receivers (haven't received the mini form the mail yet) and the normal ones are compatible with any servo connector, like Hitec, Sanwa, futaba and so on... check with a servo instead the mamba, and ensure polarity position.
rampal is offline
Old 03-08-2007, 08:52 AM
big_boss's Avatar
Just finished fiting a KO servo & Mamba Max to my 4x4 and apart from shaving the lug of the servo conector it all went very smoothly.
I had no problem inserting the Mamba conector into the micro (spektrum) reciever, where is it you're having a problem?
big_boss is offline
Old 03-08-2007, 08:55 AM
big_boss's Avatar
Oh yes, make sure of the polarity b4 you switch on though.
big_boss is offline
Old 03-08-2007, 11:56 AM
It's the JR connector. The Futaba connectors will work but you have to cut off the flang and bevile 2 of the corners to fit.
InspGadgt is offline
