Does 12v power supply affect the battery charging? >
Old 03-06-2007, 03:27 AM
Trader Rating: 52 (98%+)
Default Does 12v power supply affect the battery charging?
Does the 12v supply affect the quality of charge on the battery? ie, $200 MMR Vs. cheap $40 ones? or MMR vs. Bull dog?
I know on the HI end stereo system, a 60 lb amp rated 50 watts will sound much much better than a 5 lb amp rated 50Watts.
straightaway is offline
Old 03-06-2007, 05:18 AM
Joel Lagace's Avatar
Better supplies will allow u to multi task, run 2 chargers, a lathe ect ect....
Also better supplies are longer lasting.
The best bang for the buck is the Pyramid PSV-200. ITs 20amps with a cooling fan. 50$US!! A bunch of us have them at my track and they sure blow away the overpriced much more units. I had retired my trusty 15amp pyramid of 10years for this new light weight job. Never had issues with the old pyramid...
We got ours from:
http://www.buyreliant.com/psupplies/psv200.htm
Joel Lagace is offline
Old 03-06-2007, 06:35 AM
We got ours from:
Pyramid makes great PS. I have this classic.
That new switching one is a lot sleaker. Switching power supplies, don't produce as clean (flat) a DC voltage which, I'm guessing, is why Pyramid still makes all the others (scientists and technicians need the cleaner signal.) For most real world applications, including RC, the switching supply should work fine.
Disaster is offline
Old 03-06-2007, 02:39 PM
OOOOH thats the classic i had but yours is the delux with the cigarate lighter adaptor!
Old 03-06-2007, 02:59 PM
It weighs a pound for every amp it can supply....12 amps.
Disaster is offline
Old 03-06-2007, 03:45 PM
PIITB's Avatar
Quality....
interms of quality your charger receives YES.
Interms of what your batteries receive NO.
PIITB is offline
Old 03-08-2007, 03:52 PM
gonzo416's Avatar
Trader Rating: 39 (98%+)
does anyone know if 2 20 amp power supplies can be connected to a distribution box and get the same result as using a 40 amp power supply? the integy 42 amp costs $239 and 2 20 amp pyramid's cost $108, that's a big difference
gonzo416 is offline
Old 03-08-2007, 04:39 PM
PIITB's Avatar
no u cant combine 2 20amp PS to make them 40amps.
why the hell you would need 40 amps combined in an RC enviroment anyway.
PIITB is offline
Old 03-08-2007, 04:46 PM
To charge two MaxAmps 12000 mAh LiPos on a dual output charger at 1C
Yub, yub, cmdr! is offline
Old 03-08-2007, 09:56 PM
akuhon's Avatar
The quality ? I don;t think not so significant.... ..... IMO
I notice this since I have a digital (not analog with needle) 40amps with adjustable voltage (9 - 15V) switching PSU .... much much better than MMR and much much cheaper than MMR .....
The max. voltage for charger is 13.8V
akuhon is offline
Old 03-09-2007, 05:28 AM
gonzo416's Avatar
why the hell would you ask this question if it was answered in the post you just answered to which was previous to yours. also a turbo 35 and 2 lrp chargers have killed my 25 amp power supply
gonzo416 is offline
Old 03-09-2007, 07:51 AM
Is that your final answer?
I really suggest a lifeline.
MManson is offline
Old 03-09-2007, 08:09 AM
Tpg racer's Avatar
My question to you is why not??? I'm pretty sure you can do that......hooking up two similar power supply would actually lessen the workload of one power supply.....
Tpg racer is offline
Old 03-09-2007, 08:32 AM
Iceracer's Avatar
It may work, but its not a good practice. What is to say that both power supplies are going to divide the load equally? One may try to provide over 100% of its capability while the other sits back and delivers next to nothing. It might only take the slightest difference in manufacturors tolerances in the components of the power supply to create an imbalance. The overtaxed supply overheats, shuts down, then the first one now delivers overload and shuts down as well. A regulated power supply is not a passive device like a battery, where you can put two in parallel to deliver twice the current.
Iceracer is offline
Old 03-09-2007, 10:10 AM
gubbs3's Avatar
Don't do it. As stated power supplies are not designed for this. My first hand experience is with home stereo amps. Connecting two amps into one terminal will cause the units to go into protect mode instantly. Unfortunately, most power supplies don't have a protect mode = poof!
gubbs3 is offline
