ib 4200 battery question >
Old 03-04-2007, 10:14 PM
Default ib 4200 battery question
i have the intellect 4200ib batteries and charge them with my mrc 959 superbrain charger but my charger shows only around 3800-4000 put into my batteries when i charge them.i always discharge my packs down to .9 and charge them at 6amps.is this normal?
civiceg is offline
Old 03-04-2007, 11:18 PM
tony2's Avatar
how old are the packs?
tony2 is offline
Old 03-04-2007, 11:28 PM
it only has about 5-7 cycles in it.just bought it about a month ago
civiceg is offline
Old 03-05-2007, 03:01 AM
LOSI123's Avatar
Trader Rating: 63 (100%+)
If your brain charger allows it (im not sure) you need to increase the millivolt setting for the peak detect. And monitor battery tempreture. They should be getting to about 51 to 53 degrees celcuis when they peak. if they are not getting this warm then you definatly need to increse the delta peak millivolt setting as they are not getting to full charge / capacity.
Also make sure you tray them, to 0.9volt per cell, so that each cell is discharged individually (this is very important!) (not doing this can cause your problem!)
When discharging in series (whole pack) i would only have a voltage cut off of 1.0v per cell (6 volts for a 6 cell pack) other wise you can risk over discharge of some cells in the pack, which can also cause the symtom you are getting.
discharge in series at high amp rate first, then tray them at a low amp rate second, then allow an hour or 2 to cool then charge them,
if this does not help, then at the end of the charge feel the temp of each cell, if one or 2 of them are heaps hotter than the rest, then they are faulty/dud cells & need to be changed.
I asume your packs are side by side packs & not stick packs other wise it is very hard to tell whats wrong.
LOSI123 is offline
Old 03-05-2007, 08:13 AM
edwintklee's Avatar
Trader Rating: 23 (96%+)
all ib4200 should have this peak tempreture???
"They should be getting to about 51 to 53 degrees celcuis when they peak."
wouldn't it be too hot????
any other comment?
edwintklee is offline
Old 03-05-2007, 11:06 AM
my packs temp is about 120 degrees farentheit so i assume its fully charged.and yes my superbrain has a peak detection adjustment.i dont have a discharging tray so i discharge them with my charger, maybe this causes the problem.
civiceg is offline
Old 03-05-2007, 11:45 AM
some people say discharging your packs to zero or dead shorting it is good.im confused
civiceg is offline
Old 03-05-2007, 11:48 AM
Trader Rating: 38 (100%+)
That was for the GP3300 cells. Definately dont do that with the 4200. Never go below .9 (some say 1.0) with a 4200.
or8ital is offline
Old 03-05-2007, 12:00 PM
so whats a good discharger on a budget?
civiceg is offline
Old 03-05-2007, 12:04 PM
If you arent looking to equalize the cells then the Integy Reactor 30.
or8ital is offline
Old 03-05-2007, 12:33 PM
LOSI123's Avatar
any other comment?
52 c or 125 f is about the perfect peak temp (at exact time of peak)
for racing, to be competitive and get decent punch out of the cells.
above 132f is starting to damage them.
LOSI123 is offline
Old 03-05-2007, 12:49 PM
sorry guys but im new to electrics.got another dumb question.what do you mean by equalise?
civiceg is offline
Old 03-05-2007, 01:02 PM
LOSI123's Avatar
Equalize means "to get each cell down to the exact same voltage (0.9 volt)
it is done with a tray type discharger that has a individual cell voltage setting.
LOSI123 is offline
Old 03-05-2007, 01:06 PM
LOSI123's Avatar
like the Novak smart tray se, trinity dpd, much more ctx-d , team wave lightning ver 2.
some are available here:
They are a must for matched ib4200's, if you want to make them last more than a month or 2 & have good performance that is.
http://www.feralbatteries.com.au/category.aspx?id=%2038
LOSI123 is offline
Old 03-05-2007, 01:14 PM
so these batteries only lasts for a month or 2?
civiceg is offline
