13.5 Sintered Rollout >
Old 03-05-2007, 08:24 AM
  #31
UN4RACING's Avatar
Trader Rating: 22 (100%+)
I thought it was an after market? It looked like if shimmed like a bonded it would fit. With the small bearings.
UN4RACING is offline
Old 03-05-2007, 08:32 AM
  #32
Trader Rating: 38 (100%+)
Originally Posted by RC MARKET
I'm isn't say sale these product,
i'm saw this topic said 13.5mm BL Motor armature only !
The 13.5 in the subject refers to turns (Novak 13.5 brushless motor with Sintered Rotor) rather then a 13.5mm rotor for a non-Novak motor. Sorry for the confusion.
or8ital is offline
Old 03-05-2007, 08:47 AM
  #33
RC MARKET's Avatar
Sorry ar !
maybe i'm mistake , i'm said different 13.5 mm to 12.5mm armatures
RC MARKET is offline
Old 03-05-2007, 02:06 PM
  #34
Super Moderator
Marcos.J's Avatar
Trader Rating: 217 (100%+)
what rollouts are you guys using for the 13.5 on a 1/12th scale?
Marcos.J is offline
Old 03-05-2007, 05:00 PM
  #35
turboxrayt1fk05's Avatar
Trader Rating: 27 (100%+)
Well boyzzzzzzzzzz , just order some spurs & pinions from nexus racing to work on this gearing for the 13.5 it looks like i have get a new different set of spurs and pinions for it , also the SINTERED rotor for it , i can't wait to get it this thing
is gonna be sick
turboxrayt1fk05 is offline
Old 03-05-2007, 05:02 PM
  #36
Originally Posted by hpiracer0911
How do you figure rollout in mm can someone tell me please?
I drive
t2
57 mm tire
108/38
need anything else
gearchart.com
Old 03-06-2007, 08:07 AM
  #37
my friend is using a 88 spur with a 40 pinion and that thing crazyyyy fast
Old 03-06-2007, 08:14 AM
  #38
41-42mm rollout on rubber tires, on carpet it seemed to like about a 38-39mm rollout. The asphalt track I was running at was pretty flowing though.
GroffBall is offline
Old 03-06-2007, 12:37 PM
  #39
Super Moderator
Marcos.J's Avatar
what size tire??
Marcos.J is offline
Old 03-06-2007, 02:05 PM
  #40
Kings Kid's Avatar
Trader Rating: 35 (100%+)
46mm rears, 41p 88 spur, very,very fast
Kings Kid is offline
Old 03-06-2007, 02:42 PM
  #41
We race on a very large carpet track with medium bite and my setup for gearing on my 1/12th with a Novak 13.5 with sintered rotor, is as follows:
46mm tire, 36 tooth pinion and 78 tooth spur which rolls out to a 66.6mm roll out.
I got as high as a 72 roll out but that was past the sweet spot. It had good speed on the back straight but the punch out of the infield corners dropped off to an unacceptable level. Depending on course layout, I will go up or down one or possibly two teeth on the pinion from the setup listed. Also, as the tire diameter goes down, the pinion goes up. I am also using a LRP 07 Competition ESC.
Like some of the others have stated, you have to experiment. I just kept gearing up until I could stay with the brushed 19T on the straights. The motor was quite hot when I came off of the track with the 72 roll out but it is barely warm with the 66.6 roll out.
Crashby is offline
Old 03-06-2007, 02:47 PM
  #42
Super Moderator
Marcos.J's Avatar
thanks!
Marcos.J is offline
  #43
Super Moderator
Marcos.J's Avatar
72! wow thanks for the help
Marcos.J is offline
Old 03-06-2007, 06:36 PM
  #44
STARSCREAM's Avatar
that word sintered makes the skin on my neck crawl like scratching a chalkboard!!!!
DIE BRUSHLESS!!!! DIE!!!!!!
STARSCREAM is offline
Old 03-06-2007, 07:38 PM
  #45
Super Moderator
Marcos.J's Avatar
Marcos.J is offline
