rounded pinion screw >
Old 03-03-2007, 07:13 AM
stephen hilton's Avatar
Default rounded pinion screw
hey guys does anyone know how to get off a rounded pinion screw?
thanks t.k
stephen hilton is offline
Old 03-03-2007, 07:57 AM
pheyhoe's Avatar
you can buy a special tool i think. Sort of like a bearing puller but it has a shaft that pushes against the motor shaft and a claw that grabs the pinion. you then wind it up and it forces the pinion off. i "think".
pheyhoe is offline
Old 03-03-2007, 08:10 AM
rc boy's Avatar
use a dermal
rc boy is offline
Old 03-03-2007, 08:38 AM
Use a hex wrench you dont mind losing, put some JB weld on it, stick the wrench in the pinion, let dry, unscrew and toss in the trash.
Lon_L is offline
Old 03-03-2007, 09:06 AM
Trader Rating: 14 (100%+)
You can save that hex wrench by cutting off the tip/screw with a dremel. Cheapo L-shaped wrenches that is.
thunderbt3 is offline
Old 03-03-2007, 09:36 AM
Team EAM
Trader Rating: 79 (100%+)
Ive used a pair of needle nose pliers before. Put the tip between the motor and the pinion and pry it off....It wont mess anything up other than some paint on the motor and maybe the pinion.
EA
EAMotorsports is offline
Old 03-03-2007, 11:47 AM
haagar's Avatar
While most of the time that works fine, I've seen people start to pull the shaft out of a motor using that method.
haagar is offline
Old 03-03-2007, 01:02 PM
cheers guys got it out by buying a slightly bigger hex 1/16th
Old 03-03-2007, 07:55 PM
Regional Moderator
CarbonJoe's Avatar
Default Slot car pinion puller
Get yourself a slot car pinion puller. I got a pinion puller at the LHS that has three different size tips for different size motor shafts. Works great. Then you can easily get the set screw out.
CarbonJoe is offline
Old 03-03-2007, 08:30 PM
Trader Rating: 81 (100%+)
get a pinion puller (or better yet, split the cost among your rc buddies ) for the next stripped pinion accident
marvi is offline
Old 03-03-2007, 10:53 PM
Z.Hallett's Avatar
how much does one of those set you back? it looks really cool.
-Zac
Z.Hallett is offline
Old 03-03-2007, 11:11 PM
Trader Rating: 117 (100%+)
cut a slit on the screw with a dremel and use a flatblade to get it out...would cost cheaper than a "pinion puller"
Valentin.H is offline
Old 03-03-2007, 11:59 PM
much more motor gear puller
this one's listed at f12.99
marvi is offline
