Old 03-24-2003, 11:41 AM   #1
KevanB's Avatar
Pinion Pitch?
What exaclty does the pinion pitch account for when buying a pinion? Arent they all the same, but with different teeth amounts?
KevanB is offline   Reply With Quote
Old 03-24-2003, 12:19 PM   #2
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
Are you talking about OFF Road or ON Road car?
There're three different pitch gear one is 48,64,and BK32pitch gear..No matter what the number of teeth from pinnion or spur gear,as long the pitch are the same goes together Good luck
OVA is offline   Reply With Quote
Old 03-24-2003, 01:27 PM   #3
Super Moderator
Grizzbob's Avatar
Actually, BK pitch is more like 56 pitch(halfway between 48 & 64 pitch). Pitch simply refers to the size of the teeth, & it refers to how many teeth will fit in a specific diameter gear(in other words, a 64 tooth gear in 64 pitch should be the same diameter as a 48 tooth gear of 48 pitch). The reason why we have different pitches available is that many like having 64 pitch because changing a pinion by one tooth makes a smaller difference in gear ratio than going one tooth in 48 or 56 or 32, so you have finer control over your final drive ratio. But the drawback is that 64 pitch is easier to strip than the other(because of the smaller, finer teeth), so they're not very well suited for rough tracks(like offroad & some outdoor onroad). For that, we have the other pitches, 48's been around the longest & works quite well, & more recently Trinity brought about 56 pitch to try to make a compromise between them....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 03-25-2003, 05:05 AM   #4
sosidge's Avatar
Don't forget the metric pitches - 0.4, 0.6, 0.8.
Old 03-25-2003, 12:13 PM   #5
in america "pitch" is number of teeth per inch. 48 pitch is 48 teeth per linear inch. In eurpoe and japan metric "pitch" refers to I think cm per tooth. Tamiya 0.6 means 0.6cm between teeth. It may be mm, I'm not sure. As you can see, things are backwards in europe.
Kdonks is offline   Reply With Quote
Old 03-25-2003, 04:31 PM   #6
Iso Octane's Avatar
Or rather things are different in the U.S... metric is the standard for measurements.
Iso Octane is offline   Reply With Quote
Old 03-26-2003, 05:43 PM   #7
traxxasdude's Avatar
You need the same pitch on both gears or else they won't mesh.
traxxasdude is offline   Reply With Quote
Old 03-27-2003, 02:24 PM   #8
andrew5's Avatar
Send a message via AIM to andrew5
witch pitch is better
andrew5 is offline   Reply With Quote
Old 03-27-2003, 08:08 PM   #9
Super Moderator
Grizzbob's Avatar
Honestly, none are really better, but some are better suited to a particular situation. If you run offroad, or on a rough track & deal with a lot of collisions, then 64 pitch is likely not the best thing to use(they'd strip pretty often in those conditions), so I'd go with 48 pitch. But on a smooth onroad track, I prefer the added gearing options that 64 pitch gives me(because going up 1 tooth in pinion makes a smaller change than doing that in 48 pitch). Also, if you use 64 pitch, it's also more important to make SURE your gear mesh is just right, or the gears will wear & strip more quickly....
Bob Seay
Go Pokes!!!
Lot of 14 Pinion Gears, 2 Pinion Holders, and 3 Spur Gears (64 Pitch) MyRCTrader R/C Items: For Sale/Trade 4 02-04-2008 07:08 AM
48 pitch pinion cheehtae R/C Items: For Sale/Trade 8 10-10-2006 05:59 AM
TC3 pinion pitch oakesy2001uk Electric On-Road 2 02-15-2006 05:47 PM
32 Pitch Pinion Speed Demon Singapore R/C Racers 0 10-20-2005 09:05 AM
32 Pitch pinion Speed Demon Malaysian R/C Racers 2 10-19-2005 09:37 PM
