Integy 16x9 or Ce 35 stealth
I'm in the market for a pro charger. I have a Novak Millennium Pro but I want a charger that is better. I have two in mind but I can't decide between the Competition Electronics turbo 35 stealth or the Integy 16x9.
hey that ce 35 looks anreal, i know people that have had them for years and they swear buy them..
Can't go wrong with both, but if you have the dough, go for th CE.
like elnitro said if you have the money go for the ce 35, i actually have both the 16x9 and and turbo35 stealth(i run the turbo 35 off of the back of the 16X9-works out perfect ). i like the ce better because of its furthur adjustability and for its motor run feature to run a lathe and break in motors. also the ce has saveable setups for different batteries types.
Go with the CE 35. You'll be happy with it.
yeah, definately CE.
With the T-35BL, you can have it upgraded to do that discharge.
The T-35BL had that problem with some high voltage NiMH cells, where it wouldnt cycle it directly after a charge. You can temporarily use a 7-cell discharge, and send it in to CE to be upgaded to Stealth specs. The T-35 Stealth fixed this problem.
Regional Moderator
go the 35 much better in my mind and 16by5 is good but has have had some problems
Thanks guys!! I'll be getting a CE in three days. Also i should pass along that if you have the Quasar or Quasar pro get rid of it. A friend of mine has gone through 3 of them in the last 2 monthes. He charges 3300 at 4 amps and the charger just goes up in smoke. We don't have a clue of what we are doing wrong. I even charged his packs on my Novak millennium pro at 4.8 amps and they charged just fine with no false peaks.
You may set the CE charger fm lockoff to lockon for prevent the false peak
