Stupid N00b question time: Why is my car going backwards?!? >
Old 03-01-2007, 05:05 PM
daveaustin5's Avatar
Default Stupid N00b question time: Why is my car going backwards?!?
I've just desoldered (is that a word?!?) the motor from my tc3 and changed the armature in it to a 27t. I've put it all back together exactly as it was but now it goes backwards intead of forwards!!! I tried soldering the wires onto the other tabs (incase I got mixed up) and tried that. Smoke suddenly started to come from my speedo so I quickly soldered it back to the way it was originally.
Anyone know what I've done wrong? I've got racing tonight and don't fancy my chances racing backwards!!!
daveaustin5 is offline
Old 03-01-2007, 05:11 PM
Rysuleod's Avatar
If the endbell/can is not 27turn (fixed timing) try unscrewing it and rotating it 180 degrees. Or you can do a servo reverse on the transmitter. Usually the motor endbell is marked with the positive side clearly shown. What motor is it?
I reassembled a mod motor backwards once like I stared above. The start of the 12th scale race was not what I expected as I shot backwards at insane speed.
Rysuleod is offline
Old 03-01-2007, 05:17 PM
Originally Posted by Rysuleod
I reassembled a mod motor backwards once. The start of the 12th scale race was not what I expected as I shot backwards at insane speed.
LOL
There's no label on the can. My dad used to sort out all this stuff, I'd just race. Now it's just me and I don't have a clue! If I was to rotate the endbell would that not have the same effect as changing the wires on the tabs? I can't do servo reverse as my speedo is forwards only.
Old 03-01-2007, 05:19 PM
Also try switching the wires. Like resolder it to the tab that is opposite of what it's on.
$rusty$ is offline
Old 03-01-2007, 05:25 PM
I tried that but it smoked my esc!!!
Old 03-01-2007, 05:32 PM
On the motor?
$rusty$ is offline
Old 03-01-2007, 05:34 PM
On the motor?
Yes.
Old 03-01-2007, 05:54 PM
olhipster1's Avatar
Trader Rating: 101 (100%+)
Default Speedo and motor
on the motor their is usually a marking on the top
a + sign and -- sign
the negative wire (usually black) goes to -- side of the motor.
positive (usually red wire) goes on the other side.
same goes for the batteries, if you get the wires on the battery crossed it will cook/smoke the speed control also.
I usually recommended to people just starting to do their own maintenance to use dean plugs until you get use the wire layout.
I'm sure there are a few people at the track that can help you out.
good luck.
olhipster1 is offline
Old 03-01-2007, 06:04 PM
same goes for the batteries, if you get the wires on the battery it will cook/smoke the speed control also.
good luck.
My wires are pink and black. I've wired up the pink to the positive and the black to the negative. As you say I'm sure someone at the track can help me.
Thanks guys.
Old 03-02-2007, 12:26 AM
pookat's Avatar
At a guess you had a 19 in there before?
27's and 19's are wound in opposite directions, this reverses the motor.
You need to swap positive for negative, you say you did this but if smoke came out of the speedo then something was shorted. Are you sure you didn't solder onto the 2 seperate positive terminals for example? At a glance that would look right but be very wrong.
Rewire it "backwards" and make sure there is nothing shorting between +ve and -ve.
pookat is offline
Old 03-02-2007, 07:37 AM
bukil's Avatar
Trader Rating: 39 (100%+)
Post up some pics.
bukil is offline
Old 03-02-2007, 10:31 AM
brad996's Avatar
unless Im wrong the neg on the motor should be a blue wire unless someone has changed it and the battery neg should be black at least thats how my novak stuff is
brad996 is offline
Old 03-02-2007, 10:35 AM
shaggys40oz's Avatar
Did you install your diff backwards?? I know that in my tamiya tb-02 you can actually install the diff backwards, once i installed my diff in the front backwards and my front and rear wheels turned towards each other ... it was prety funny when I put it on the track and all it would do is donuts!!!
shaggys40oz is offline
Old 03-02-2007, 12:52 PM
PoLsKiE's Avatar
Trader Rating: 30 (100%+)
lol sounds funny i would love to see that
PoLsKiE is offline
