Capacitor
Originally Posted by surrealmaterial
Hey,
i just got my keyence rapida pro, and the guy i bought it off gave me a 25v 2200uf capacitor, is it ok to run it with this capacitor?
Cheers
Cheers
so does the voltage matter.......or is it only the bigger the uf the better?
But I don't know of anyone that sticks a cap on a Rapida Pro (that's one of the appealing things about the esc, "No Caps").... and if you stick an external schottky you need to turn the internal schottky off...
so i dont need to run anything on it? cause in the instruction manual it says to put some capacitors on the motor between the positive and negative, the positive and the can, the negative and the can.......but ive lost all the original ones it came with............so is it safe to run with out anything on it except battery and motor?
It is safe to run, unless you notice strange behaviour coming from ur car.
What you were originally talking about is cap's to assist most (not the Keyence) esc to deliver punch or more filtering. They are large in size (for RC cars). The caps on the motors are small and it would be hard to find current motors without them already built-in by the motor manufacturer...
