need HELP
Old 02-27-2007, 08:32 AM
edward Haywood's Avatar
Default need HELP
Every time that i pull the throttle the car will go in reverse when i pull the other way it will go forward its backwards please help ,and i am really new to rc so please be easy with me thanks.
edward Haywood is offline
Old 02-27-2007, 08:39 AM
steve a.'s Avatar
What kind and model radio do you have? So i can tell you how to reverse the throttle
steve a. is offline
Old 02-27-2007, 08:43 AM
JR racing XR2I 2 channel
Old 02-27-2007, 09:11 AM
timmay70's Avatar
What electronic speed control. Most will reverse automatically if you reset the speed controller.
timmay70 is offline
"Straight from the Xr2I manual"
1. Turn the transmitter power switch on.
2. Press the MODE key to access the Function Mode.
3. Press the MODE key until REV.NORM appears in small
letters to the right of the screen.
4. Press the CHANNEL key to select the channel to be
changed (ST = Steering, TH = Throttle). be sure to only change the th=throttle, if you switch the steering it will be backwards also.
5. Press the INCREASE or DECREASE keys to move the cursor
to the desired direction.
6. To exit the Function Mode, either turn off the transmitter
power switch or press the MODE and CHANNEL keys at
the same time.
Heres the link to the manual just in case you dont have it
http://www.jrradios.com/ProdInfo/Fil...127-manual.pdf
Dtech is offline
Old 02-27-2007, 09:16 AM
Timmay70 has a good point. I didnt think of this. Been a while since using a speed control w/ automatic setup.
If your using a speed control w/ automatic setup this could very well be your problem. Give Timmay70's suggestion a try before playing w/ your radio settings.
Dtech is offline
Old 02-27-2007, 09:53 AM
Thanks for all of your help I had to reprogram my remote its working fine now thanks.
