pro 4 help needed
gentlemen,
can any one help on gearing for this car with a 540 motor which spur and pinion please
also for a losi xxx s same problem as well gearing needed for a 540 motor
thanks
minnesh
thanks
minnesh
howzit minnesh, are you using 48dp or 64dp Spur gears? what tyres are you running? foam or rubbers??
hello rocket
thanks for the help on the pro 4 i have called denket and they out of stock however more are on order
with regards to the losi pinion is 34 spur is red 86 i think
imn going to try a bigger pinion and see what happens
thanks
minnesh
thanks
minnesh
