HOTBODIES - AH12 Conversion parts >
Old 02-25-2007, 07:25 PM
SWTour's Avatar
Default HOTBODIES - AH12 Conversion parts
On the HotBodies AH12 Conversion part#HOT90200 are the lower plates available seperately?
I'm assuming by the pics I've seen this rear pod allows the use of the current L3/L4 style rear pod plates to be used.
I have several of the old ROADSTAR 1/10th scale cars I'd like to try adapting this lower plate to.
SWTour is offline
Old 02-25-2007, 07:37 PM
CarlosG.'s Avatar
Are you asking about the bulkheads that the motor and axle mount on or the bottom grahite podplate. If you are asking about the bulkeads then the one that comes with the L3\L4 will work even the ones that Calandra sells will work as well. However, if you are asking about the bottom fraphite podplate, it will not work.
CarlosG. is offline
Old 02-25-2007, 08:43 PM
SWTour's Avatar
I guess that partially answers my question.
I wanted to know if the L3/L4 pod plates (Bulk head and motor plate) fit the AH12 conversion.
I also want to know if the Lower Pod Plate (Graphite) is available seperately...
If it is, I need a supplier and part number. I want to try one on one of my old HPI RoadStar cars and convert it to the L3/L4 (instead of the old 10L style bulkheads) The other dimensions appear to be the same where it mounts to the rear of the chassis...so this may be a cool upgrade on an old dinosaur.
SWTour is offline
Old 02-25-2007, 09:13 PM
CarlosG.'s Avatar
You might want to contact Hot Bodies directly to see if you can get the lower podplate from them. I have been looking for parts as well, but only could fine some parts but not the ones I needed ( like the graphite pieces). Stormer has some of the parts, but not everything. Here is the link to what I found: http://www.stormerhobbies.com/cgi-bi...umb=on&smode=0
CarlosG. is offline
Old 02-25-2007, 10:13 PM
rc-zombies's Avatar
the hammer 12 does not use a T-bar plate like the 12L3/L4 series. the hammer parts are available seperately...but mostly overseas in HK or Japan.. the conversion kit has been discontinued for quite a while now... so getting any replacement parts may be difficult.. probably cheaper to buy the whole conversion kit... on sale now at Stormer Hobbies...
rc-zombies is offline
Old 02-25-2007, 10:22 PM
SWTour's Avatar
The back/rear suspension on the AH-12 uses the same basic design as the old HPI RoadStar and HPI F-1 cars...except it appears to use the more modern L3/L4 style motor and bulkheads.
I actually have considered purchasing one of the kits from Stormer, but $70.00 for a lower pod plate to experiment with on a dinosaur car would be kind of silly. If I could find just the lower plate for $15.00 bucks or so, that would be different.
SWTour is offline
Old 02-26-2007, 01:02 AM
corallyman's Avatar
Trader Rating: 101 (100%+)
SWTour,
Contact DPowell at www.powellracingcomponents.com
He makes some parts for the Hammer 12 car, nothing is shown on the website but just email him and he will respond.
Steve
corallyman is offline
Old 02-26-2007, 09:31 AM
rc-zombies's Avatar
<1/12EP on road car >
90200 "Hammer 12" conversion kit
90211 AH12 chassis \4,500
90212 AH12 upper pod brace \1,000
90213 AH12 lower pod brace \1,400
90214 AH12 rear chassis brace \1,000
90215 AH12 roll brace \800
90216 AH12 spring brace \700
90217 AH12 roll tower \1,200
90218 AH12 pivot ball \800
90219 AH12 shock spring set A and B, C \600
90220 AH12 Rolls pulling (1.0mm) \380
90221 AH12 rear suspension \900
90222 AH12 spacer (C) \120
90223 AH12 bis set \600
Old 02-26-2007, 04:39 PM
joe........i have a hara chassis only that i will sell you cheep...30.00 shipped. lmk
gotyournumber is offline
Old 02-26-2007, 06:29 PM
SWTour's Avatar
Charlie.
SOLD~ lmk where and how you want it...(Paypal???)
SWTour is offline
