Which touring car should I Buy Please HELP!!!
Ok I am getting into touring class and have a few questions:
I have seen a couple option I could go with:
HPI Sprint 2 RTR
Team Associated TC4
I assume there are other options and I am am willing to hear them. If I cannot find a used car here I may buy new at towerhobbies. Both are RTR with everything and are the same price. Which is a better car the Team Associated or the HPI. I would like to get in the touring class fairly cheap.
Also I see kits of the TC4 for $200 but you can find RTR with remotes and everything for $40 more is there something special about the kits or is the RTR the same exact car.
Thanks In Advance
GunLocators
HPI Sprint 2 RTR
Team Associated TC4
Thanks In Advance
GunLocators
Personally, I would go with something like the TC4, or wait 'till the TC5 comes out.
tamiya TA05
HPI Sprint 2 RTR
Team Associated TC4
Thanks In Advance
GunLocators
HPI Sprint 2 RTR
Team Associated TC4
Thanks In Advance
GunLocators
Why are the kits almost as expensive as a complete rtr? I do not understand is there something special about a kit?
not bad for $159.99
are you going to be racing, or bashing? if you are racing, definately get a kit. if not, you may consider an RTR, but putting kits together is half the fun
I would go with the TC 4 RTR. The difference in the kit is you have to put it together yourself which if you have not done it before, it will take about a week. The kit comes without a motor, electronic speed control or any electronics such as transmitter so you have to buy all these parts seperate which is going to cost you about 400-550 all included. The parts in a kit are totally different and better made such as graphite and titanium which usually makes the car lighter. It is a challenge to put a kit together without being familiar with R/C without needing help and not making a mistake. You cannot go wrong with the TC4, I have 2 of them. The TC5 that is coming out is going to be in kit form to begin with I believe. Start out with a RTR and get familiar and then build you a kit for your second car. Best of luck.
Gofastrlbrown
Gofastrlbrown
ge
If you want the best car for your $, then an xray T2007 is it. there are used ones on tech allmost weekly. Best handling car I've ever driven. Most consistent in handling. I've seen several drivers at our local tracks turn faster laps going to the xray and leaving the tc4, losi's etc. I've personally knocked a full second off of my own lap times since I've switched
My 2 cents worth
The HB Cyclone is only $199 on Stormer Hobbies. It's a kit, but you could find cheap gear on Tech for a nice amount.
BTW: Stormer Hobbies is the ONLY way to go for parts and stuff.
My 2 cents worth
Hot bodies Cyclone at Stormer hobbies now for $199...not the S either...full carbon fiber and all.
Tamiya TRF415 from Tamiya America for $275...
The next best option after that if you want something a little more affordable would be the Tamiya TA05, one of my personal favorites.
