Wiring up a Novak GTB...... >
Old 02-25-2007, 02:57 AM
GundamWZero's Avatar
Default Wiring up a Novak GTB......
I picked up a Novak GTB Package (with the Velociti 3.5R motor) and I am trying to fit it neatly in an TB Evolution III. The thing is, I hate the long wires that comes with it. I want to cut down the large wires to the motor and re-solder them but I don't know if that will effect the motors performance. Can anyone show me either some pics of the shortened wiring or tell me if it is a good idea........
GundamWZero is offline
Old 02-25-2007, 03:04 AM
A Ilievski's Avatar
Trader Rating: 39 (100%+)
cutting the wires is fine, the only reason why it comes with long wires is so it can fit most cars. I.E Buggys, JRX'S etc etc. Then for cars like cyclone you cut the wires to fit.
A Ilievski is offline
Trader Rating: 81 (100%+)
i dont know if it will void novak's warranty, but ive cut the 3 motor wires (shortened to about 2.5") to fit by BD and it runs fine about the sensor wire, it would be better if you fold it up a few times then use the plastic spiral thingy to protect it. the nice thing about the gtb is if ever you will transfer it to another car, you can rewire it easily because of the external wire tabs again, dont know if this will void the warranty
marvi is offline
Old 02-25-2007, 03:07 AM
Thanx guys.....I am going to shorten them. Tomorrow I will run brushless for the first time.....
Old 02-25-2007, 03:14 AM
Default Another Question......
how would you gear a brushless motor? Like a modified motor or like a stock motor? I was going to use my same pinion (37T) with this motor. Do I need to step up or down?
Old 02-25-2007, 03:31 AM
for the 3.5R, the range is 10.50 - 11.50. but try to stay near 11.00+ and temp your esc and motor. the ideal temp range is somewhere in the manual im running 11.20 in my BD and its too fast for me (got used to running stock ) havent thermaled since but i did add another 1" 5v fan on the esc
marvi is offline
Old 02-25-2007, 11:50 AM
burbs's Avatar
cutting the motor or battery wires does not void any warrnty.. These are made to be used at whatever length you need.. novak sells re wire kits as well, so if you cut them short you can re solder og length wires back on.. comes as a pack of 2 sets of re wire for 10 bucks..
burbs is offline
Old 02-25-2007, 11:39 PM
Is this oke??
http://www.putfile.com/pic.php?img=4832362
Rob Janssen is offline
Old 02-25-2007, 11:50 PM
Trader Rating: 49 (95%+)
what gauge wire did you use? other than the wire looking a bit thin, looks lightweight to me.
loopedout is offline
Old 02-26-2007, 06:38 AM
14 AWG, I thought 14 AWG is also std. but I'm not sure about that.
Old 02-26-2007, 07:34 AM
SARCAR_Revmax's Avatar
Originally Posted by Rob Janssen
Nice looking car you have there. All Novak and HB purple.
SARCAR_Revmax is offline
Old 02-26-2007, 08:22 AM
Thx.
Old 02-26-2007, 11:26 PM
AngryAsian's Avatar
Actually, I think lots of speedo's use 13g wire. There's not harm in using 14g really. some people wear by a certain gauge. I re-wired mine with 12g when I re-installed it in the car. That said - I'm not sure if there's any advantage.
Some people have commented that there's extra acceleration, but that the speedo also shuts down easier on 12g. Or the motor overheats easier as it can pull more amps. I can't really say either way...
AngryAsian is offline
Old 02-26-2007, 11:31 PM
The Evicerator
Our standard wire shipped with the GTB is 14 AWG.
Steve Weiss is offline
