Looking for my first discharger, here's what I want (does it exist)?
I'm not after anything to fancy so imagine this.....
https://www.ssl-stormerhobbies.com/c...&pn=INTE200520
with a digital read out of capacity, discharge time to preset cut off and maybe internal resistance. Again nothing to fancy.
The question, is (and I haven't been able to find anything myself so far) there a discharger that will do all of the above.
I'm not worried about each cell in a pack (nice to know but not essential) just which of my existing packs is the best and something where it wont matter if I forget to come back in time because it at least keeps the data from the last pack.
What I don't want is a discharger that (like I read about the Trinity model) takes like two hours to flatten a fully charged pack.
Thanks in advance.
Thanks in advance.
How about theLightning V2 Dsicharge/Equalizing System
"A fully charged 4200mAh battery (~4400mAh) can be discharged to 0.9V per cell in about 30 min"
http://www.teamwaveonline.com/2007/products01.htm
Edit: I took a closer look at the picture and it still might work as my batteries have the corally sockets on top of the cells (like only 1mm or so away from the cell) and it would mean turning the battery upside down from how it's pictured.
Do you think this discharger would still make contact with the terminals if the battery was raised up not much more than the diameter of the connectors?
I hope they would fit but as it happens I can't find anyone with them in stock yet.
Sounds like you want a Spintec Battery Manager.
Check this out:
https://www.ssl-stormerhobbies.com/c...=ns&pn=SPI1000
You might be able to pick one up second hand.
I have one (but not for sale) and it does take a while for packs to discharge (a few hours from fully charged), but you can connect it and leave it over night till it's done without any dramas.
Their web site is:
http://www.spintec.nl/
Check this out:
Their web site is:
Go with either the spintec battery manager and an equalizing tray or the trinity dpd. The spintec and the DPD both read out all the info you need
. The DPD discharges each cell individually at the 30 amps pulse which is nice while the spintec discharges the pack at 35 amps pulse. what kinda cells are you using?
Michael S.
Michael S.
Orion used to make a 20a discharger with digital readout.
Question- Why would anyone want to go with a Spintech over a Trinity Dyna Pulse for $30? Plus how many people actually use 7 cell batteries? I'll bet it's far fewer than those who use 4.
https://www.ssl-stormerhobbies.com/c...pl?pn=tri22001
The info on the Spintec on the stormer site is old, the new v2 version does 4 to 8 cells.
Check this:
http://www.spintec.nl/batman2.shtml
Check this:
spintec v2
or
much more d2
I use the much more with corally connects
do a search on the trinity and find pics of the inside........
or
much more d2
