Turbo35 to a PC? >
Turbo35 to a PC?
Turbo35 to a PC?
Old 02-23-2007, 05:41 PM
TEM
TEM's Avatar
Default Turbo35 to a PC?
Trying to link up my T35 to the PC. I remember doing it like 5 years ago but forgot the settings on Hyperterminal. It comes out as 2 lines of jibberish code instead of the ASCII graph of stars you're suppose to get. The link for instructions on the CE site is dead.
TEM is offline
Old 02-23-2007, 08:22 PM
Check the comm port settings. It should be 9600/8/n/1
jiml is offline
Old 02-23-2007, 08:31 PM
rbboy's Avatar
where can i buy that serial port?
rbboy is offline
Old 02-23-2007, 09:03 PM
TEM
TEM's Avatar
A computer store will have that exact cable to connect the T35 to a PC. Just a straight through male to female. It'd be like 6 bucks. I made my own for about $1.50 with 2 connectors from an electronics store and some wire. Thank god CE is honest and don't make you buy an exclusive and expensive cable like other RC companies!
I actually tried those settings but it didn't work. The last time I did it was with my old notebook with win98. I'm almost confident XP the same but I'm getting jibberish still.... It won't kill me if it didn't work but it is very useful if you know what you are doing.. I wonder if the bios settings got anything to do with it... I"ll keep fiddling with it.. Thanks Jiml.. that was exactly the info I was looking for.
TEM is offline
Old 02-24-2007, 07:49 AM
I use a straight thru cable and a gender changer, borrowed from work
If you're getting jibberish it's probably the baud rate. Maybe it's 19200?
jiml is offline
Old 02-24-2007, 08:38 PM
TEM
TEM's Avatar
"gender changer, borrowed form work"??? Where do you work?
I went through all the baud rates and was NOT it. I'll try it on a different computer when I get around to it.
TEM is offline
