pls help
Old 02-21-2007, 10:06 PM
Default pls help
i
civiceg is offline
Old 02-21-2007, 10:19 PM
chk for Tweak on the chassis . make sure your shocks dont have air in them . this will make them work un even and your car will have a push and seem to spin out .. try this ( if your car is spinning out to the left turn the shock collar on the left rear shock to increase resistance .. drive it and see how it drives . if it helps , then you might want to rebuild your shocks set , your ride height chk/set your droop ... good luck and have a good running ....mb.
mb racer is offline
Old 02-25-2007, 08:19 PM
it
civiceg is offline
