Old 03-20-2003, 10:59 PM   #1
jcr
Foam Vs. Rubber?
Can you compare these two types of tires for me? I know the foam has more grip and cheaper. But which one last longer?
jcr is offline   Reply With Quote
Old 03-20-2003, 11:25 PM   #2
spitfire's Avatar
Send a message via AIM to spitfire Send a message via Yahoo to spitfire
Do a search for that topic. As im sure its been covered a few times. And to answer you question Directly. I haven't a clue. Never ran on foams yet
spitfire is offline   Reply With Quote
Old 03-21-2003, 08:52 AM   #3
First, I have never raced on rubbers, so I only have second hand knowledge of that, but here is my opinion.
Foam will generally last longer. The problem that I hear of for rubber tires is that they are only at their best for the first few runs. Foam tires handle more consistently through their life, and actually get better as they get smaller. My car REALLY comes to life when the tires get down to about 2.20 inch diameter.
Jeff Gilligan
gotpez is offline   Reply With Quote
Old 03-21-2003, 10:21 AM   #4
popsracer's Avatar
Default Foam Vs. Rubber?
Because of the different traction properties of Foams, in ideal conditions, Foams will allow you to get on the Throttle MUCH sooner, scrub less speed off in a corner and thus being faster.
However, generally, for Foams to work, you much already have enough traction for Rubber Tires. If the surface is even slightly Dusty, Foams will be at a disadvantage.
popsracer is offline   Reply With Quote
Old 03-21-2003, 02:20 PM   #5
jcr
Well someone lend me a set of foam to try yesterday and i felt it gave me a lot of grip over the rubber tires. And I'm mostly running on indoor carpet so I think foam will for sure work. But I want to which one will last longer(as in the life, not performance)? And what are the maintenance require for foam?
Old 03-21-2003, 08:51 PM   #6
popsracer's Avatar
For Carpet racing you'll have to have someone else give the answer.
On Asphalt, Rubber definitely lasts longer than Foams, providing your not running too soft of a compound either way.
Old 03-21-2003, 11:37 PM   #7
007yoshi's Avatar
Sorexs on carpet are wearing very slowly for me. Ive ran mine for 4 weekends now and still the mold line is visible almost and I use paragon each run
Personally I choose not to run foams because: you have to true them 2) they chunk 3) most big races wont allow foam in stock tc anyways so why get used to them
007yoshi is offline   Reply With Quote
FOAM TO RUBBER 32819toon Electric On-Road 7 07-22-2008 08:49 PM
foam or rubber? civiceg Electric On-Road 18 04-27-2007 04:59 PM
Foam or Rubber? pokpok Indonesia Racing 12 04-08-2004 11:41 PM
Foam Vs Rubber fastolfart Australian Racing 66 07-09-2003 04:04 PM
foam or rubber Skid Marks Northwest Racers 65 02-27-2003 11:14 PM
