Control Tire Tactic >
Control Tire Tactic
Control Tire Tactic
Old 02-21-2007, 12:40 PM
Guo Chean's Avatar
Default Control Tire Tactic
If you guy only limit to 2 set of new rubber tire on 3 round of qualifying what will you guy doing? thanks
Guo Chean is offline
Old 02-21-2007, 01:41 PM
there are few choices but also depended on the track
1) rotate the rear one to the front
2) keep running the old one as sometimes it gives better lap time then the first run tire.
3) steal one or nicely take one set from your friend without him knowing it.
I usually compare the first run and second run lap time then decide if the third run and main is worth the new fresh tire. usually i have new set in main.
~Ming
aoizip is offline
Old 02-21-2007, 01:57 PM
Guo Chean's Avatar
~Ming
i believe the main they will allow you to used another fresh tire.
Old 02-21-2007, 02:00 PM
Trader Rating: 32 (100%+)
If they let you use a fresh set in the main, use one set for round 1 & 2 (rotating), then the 2nd set for round 3.
A. Rhodes is offline
Old 02-21-2007, 02:05 PM
PW
PW's Avatar
Don't ever rotate left to right. The car will always feel tweaked on rotated tires
PW is offline
