Old 04-04-2007, 04:55 PM   #121
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Just received my confirmation on the shipment of my parts order for my EVO2 parts. Very nice and it looks like everything was in stock so even better.
ST Racing Concepts (STRC)
Old 04-08-2007, 06:57 AM   #122
Trader Rating: 45 (100%+)
Originally Posted by fast-ho-cars
i noticed the pod plates were cut a lot lower than my CRC pod plates and there was 6 .030 washers in the kit. looking at the older C12 evo2 instructions that came with it, i installed one. i have run 12th cars in the past or have seen where the motor breaks the bottom plain. the Delta P12 i had did alot, a racer in AZ had a Trinity car that did slightly...think it was a Reflex-12? today's 27T and 19T motors the flat spots you might be able to use 2 washers.
right now having taken the .030 washer out from under the front pivot and rebolting it....the two 2-56 screws have or are causing a slight load creating a droop in the upward direction.
i know many things changed from the first to the second version, like the cross brass is now infront of the aluminum standoffs not in back. yep i had to redo it after following the older instructions...no biggee just want ot make sure i didn't miss anything new that was to be done before i grind.
I noticed this last night. I was thinking about countersinking the t-bar, but then it would probably be too weak. So I dremeled a notch in the lower plate so the screw cap doesn't touch the lower pod plate.
Apex is offline   Reply With Quote
Old 04-19-2007, 03:09 PM   #123
beyondthepack's Avatar
Send a message via Yahoo to beyondthepack
...not that this is a "show and tell" but maybe a bump lol....oh nevermind, just crazy canuck talk
AE B5R - SC10.2 - Outdoors
AE TC7.1 USGT - INFINITY IF14 - Indoors
LRP - REEDY - FUTABA - IDEAL HOBBIES - RC404
beyondthepack is offline   Reply With Quote
Old 05-01-2007, 12:28 PM   #124
Josh, please post your winning setup that you ran at the Invite.
Ramyuras is offline   Reply With Quote
Old 05-02-2007, 07:21 PM   #125
Big B's Avatar
I am thinking of getting a CEFX C12 EVO Green, but I have never ran a 1/12th, can someone tell me what size screws it uses Standard or Metric, and what if any hopups are good?
Big B is offline   Reply With Quote
Old 05-02-2007, 07:47 PM   #126
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
The kit that I had was standard screws. I don't know if the green front bumper (in the picture a couple posts before is included) but that would be a good choice.
Here is a list of 1/12th items that we sold a lot of. Are they necessary, probably not.
Calandra Dura Shock
Calandra Upper Arm Mounts for the front suspension
Calandra Delrin Pivot Sockets and Balls for the t-bar.
IRS also has some of these parts as well. Are they needed, probably not. The car with the stock parts will work just fine.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 05-02-2007, 08:17 PM   #127
reilly's Avatar
Hey Boys,
Here is what we ran at the Gate/Stock Nationals
Front
Lube on kingpins: Kyosho yellow grease
Springs: 0.018
Blocks: 5 deg - white shim on both side of upper arm
Camber: -2
Front Ride Height: 3.5mm - 4mm
Rear
T-plate: C12 .062 T-Bar - Med - C12 Only
2 screws
Tubes: Kyosho yellow grease
Ride Height: 4mm
Shock
30w Losi
stock C12 spring ( olive Assoc. )
Tires
Front: Dbl Pink Wrap
Rear: Yellow Wrap
Speed 12 body
* ride height a little high but the track is a little bumpy. Typ. 3-3.5 all around
The car was very fast and easy to drive. I qualified 2nd in the open class and
only my little mistakes held me back. This was also the same set-up we
ran at the nationals at home.
Hope that helps.
James Reilly
CEFX, Express Motorsports, Parma, Reilly Paint
reilly is offline   Reply With Quote
Old 05-02-2007, 11:16 PM   #128
Big B's Avatar
Thanks Kraig. Is there a parts list for the stock kit somewhere? I will be running up here at SIR, any suggestions for setup?
Old 05-02-2007, 11:22 PM   #129
Big B's Avatar
Almost forgot, Josh when will one of you guy who is great at running 12th scale put together a book for all us newbs out there who dont understand how the chassis works, something like the XXX Main one for Touring?
Old 05-03-2007, 05:05 AM   #130
Rich Chang has a wonderful 1/12 cheat sheet. Just can't remember which thread I found it in. Most likely 1/12 thread.
Jason
Stampede is offline   Reply With Quote
Old 05-03-2007, 05:27 AM   #131
wyd
Tech Legend
wyd's Avatar
http://richardchang.com/hobby.php?topic=112setup
Old 05-03-2007, 09:20 AM   #132
Big B's Avatar
Thanks, I will check it out
Old 05-03-2007, 09:43 AM   #133
b-man777's Avatar
Default cefx oval
hey all:Is there anymore news as to when if ever cefx will release their new 1/10th and 1/12th electric oval cars?Also who other than josh cyrul is on the cefx team?thanks for the info
b-man777 is offline   Reply With Quote
Old 05-03-2007, 03:58 PM   #134
jag88's Avatar
1/12 scale --- Andrew Ellis, Andy Power
Oval --- ??
jag88 is offline   Reply With Quote
Old 05-03-2007, 08:22 PM   #135
EA also
march to my own is offline   Reply With Quote
The Racing Thread chicagokenji Micro and Mini Scales 8 02-20-2007 07:40 AM
CEFX Raceway - Summer Racing Schedule Josh Cyrul Track Locator Forum 0 05-30-2006 05:16 PM
Drag racing thread mrgsr Australian Racing 4 11-05-2005 01:10 AM
GS Racing S.U.T. Thread Fatboy Joe Monster Trucks 5 07-27-2004 07:53 AM
Mad-Rip Racing Thread (where 'd it go?) amusicwiz Florida Racing 1 03-28-2004 07:03 PM
