Old 02-02-2009, 07:02 AM   #616
Originally Posted by drover View Post
Hi I want to know the diference between the Phoenix and Phoenix J-spec.
The J spec is the Japan version (for asphalt). I don't remember what all is different but I do know that the chassis has more flex.
Fred_B is offline   Reply With Quote
Old 02-03-2009, 09:51 AM   #617
Originally Posted by champebi View Post
Thank you! Mr.Josh Cyrul.
We feel your support glad. We used CEFX Phoenix thanks to your support and were able to go into A-FINAL in two classes. We thank for your having prepared the best car.
CEFX Phoenix which Josh Cyrul used is T-Bar car.
Congratulation to Josh Cyrul and all the CEFX racing Team
drover is offline   Reply With Quote
Old 02-03-2009, 04:08 PM   #618
champebi's Avatar
Smile Snowbirdnationals
I did not use the "J - SPEC" chassis in this Snowbirdnationals. We received a chassis of US - SPEC from Josh on Monday. We assembled the car on the day. The chassis of the "US - SPEC" gave us the best result fantastically. I think that the balance of splendid CEFX Phoenix contributes to the fact that we with a little experience of the carpet road surface which is a high grip were able to go into A - FINAL.
A "J - SPEC" chassis is the chassis which is Flex of the 2.5mm thickness. I usually put it together in this chassis, and it is T - Bar of the 1.6mm thickness to use. Most circuits are asphalt road surfaces in our country, Japan. I think that a grip of this Snowbirdnationals resembles the grip of the asphalt road surface of the current Yatabe arena very much. We test setup of "US - SPEC" which we used this time in a state as is in Japan. I think that the best result is provided on this test. Of course I think that the setup of the details has to change it.
champebi is offline   Reply With Quote
Old 02-03-2009, 04:27 PM   #619
champebi's Avatar
Default Snowbirdnationals
This car is a car of Josh Cyrul.
Old 02-03-2009, 04:32 PM   #620
champebi's Avatar
Smile 1/12 GTP 10.5
This car is a car of 1/12 GTP 10.5 of Naoki Watanabe.
Old 02-03-2009, 04:36 PM   #621
champebi's Avatar
Default mistake...
I was wrong. This is 1/12 10.5 GTP cars which I used of Naoki Watanabe.
Old 02-03-2009, 09:23 PM   #622
hanulec's Avatar
Trader Rating: 27 (100%+)
Attachment 413976
looks like josh was running the new associated 12r5-based front end. interesting....
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 02-04-2009, 04:28 AM   #623
I also want to observe that the center shock it is not the vcs, it is hot bodies?
Old 02-04-2009, 09:39 AM   #624
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
Hey Josh,
Great seeing you again at 360, thanks for the advice and congrats on the wins. I just pruchased the Phoenix and have a few questions.
1.) On your car, I noticed thin spacers under the motor plates? Was this to raise ride height or because the brushless motors are larger in diameter than brushed?
2.) could you post your set-up? T-bar thickness...etc...
3.) Noticed you used the new ASC front-end...with a flat servo? Last time I noticed you had the servo angled, although you were using the older ASC front? Do you have preference and why?
4.) KO Brushless speedo...you still use a RX pack? Thought the new speedo's with 4-cells do not need an RX pack...or is this just a preference?
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 02-04-2009, 05:20 PM   #625
JamesReilly's Avatar
Trader Rating: 58 (100%+)
Yes it's a hot bodies shock, it's very nice.
Reilly Paint ([email protected])
JamesReilly is offline   Reply With Quote
Old 02-04-2009, 05:57 PM   #626
~McSmooth~'s Avatar
DeSoto Racing * Franchise * Pro-One * Team Scream * Power Push * Team Ass
Badly influencing a new generation of racers!
~McSmooth~ is offline   Reply With Quote
Old 02-04-2009, 10:01 PM   #627
So are those Reilly paint bodies!!!
Brian Anthony is offline   Reply With Quote
Old 02-05-2009, 09:31 AM   #628
Josh Cyrul's Avatar
Hello Everyone,
After finishing up Monday with Angel and the girls at Magic Kingdom it was finally Tuesday and time to come home. Adding to the exaustion was a fun day dealing with Airtran who screwed up multiple times and instead of getting home around 5:30pm it was about 1am!! So, after sleeping for the past day and a half straight, it's time to catch up on things.
First, I want to thank all the CEFX drivers for a great effort and a great race. It was a lot of fun and I am very proud of our efforts this year. Ok, onto the questions:
Link Car - With the coming days of the single cell Lipo coming I figured it was time to start testing a link car. Eli Ezrow had previously run for so many years with a CRC link car before switching to CEFX so I figured he would be a great person to start the initial testing with. Being the testing would be at a major, I didn't have high hopes but at times the car looked extremely good with a lot of steering. I think at one point, Eli was even 2nd in qualifying but slid down the order towards the end. Being the first run with a link car, I definatly have a lot to learn but hopefully we can get up to speed quickly as the single cell Lipo will be raced in some classes in the near future (IIC I think).
My t-bar car - Yes, I did make myself a test chassis with some things moved around and it was capable of using the new AE front end. The main reason was to test the build, and set-up of this front end. I also wanted to see how the car reacted with an aluminum front bulkhead and using a suspension arm that "flipped" from one side to the other on tolerance (it was about .5mm off). While the car drove well, I still think my standard car was better and I will continue testing this a bit more at the coming races as I plan our future projects.
We include the AE VCS center shocks in our kit as that was the norm in the past before the Hot Bodies shock arrived that now a lot of other companies have copied. The car still works well with the VCS but the Hot Bodies is more maintence free.
Hey Carl:
1) The spacers were to make the bottom plate flush with the motor for easier ride height measurement. A lot of drivers will measure the bottom plate and forget the motor hangs out the bottom. So they set ride height and can't pass tech since the motor is out the bottom of the pod. It doesn't change the handling.
2) I'll post it in the next post.
3) I have prefered the servo on the angled mounts as of late. With the new front end, the way the aluminum bulkhead is you can not do this as the steering tie-rods hit on the aluminum bulkhead. I was dissapointed about this so I just ran the servo flat. Again, this was just a test car to learn more for the future.
4) I didn't use a reciever pack. I have it in the car if I need/want to but it's mainly there as an option and to balance the car and ad weight.
Brian - Yep, James paints all my stuff these days!!!
Destiny, Ko Propo, Hobby Wing, Ulti Racing Tires, Protoform, Xenon Racing, Pivothead, Vizon, TQ Wire & Hella Graphics
Josh Cyrul is offline   Reply With Quote
Old 02-06-2009, 07:53 AM   #629
Josh you have a PM.
Jeremy Otis is offline   Reply With Quote
Old 02-06-2009, 09:02 AM   #630
Trader Rating: 45 (100%+)
Cool. Can't wait to get the link conversion when it's ready. Still not a bad showing for Eli and the link car on its first major outing.
Apex is offline   Reply With Quote
The Racing Thread chicagokenji Micro and Mini Scales 8 02-20-2007 07:40 AM
CEFX Raceway - Summer Racing Schedule Josh Cyrul Track Locator Forum 0 05-30-2006 05:16 PM
Drag racing thread mrgsr Australian Racing 4 11-05-2005 01:10 AM
GS Racing S.U.T. Thread Fatboy Joe Monster Trucks 5 07-27-2004 07:53 AM
Mad-Rip Racing Thread (where 'd it go?) amusicwiz Florida Racing 1 03-28-2004 07:03 PM
