Old 09-17-2007, 08:18 AM   #301
subaru73's Avatar
Trader Rating: 41 (100%+)
Default general
Hello i just recieved a cefx gen 2 car and was wondering what woulb be a good starting set up for carpet.Thanks for your help.
Tamiya Ta07 Tamiya evo5 ms,Tamiya Ta05r Tamiya FF04 rm01 Tamiya Ff03R
Futaba 4Px radio lrp speed control
Cfx paint works Fantom Racing apex Rc tq hobbies acer racing Hebki design works
subaru73 is offline   Reply With Quote
Old 09-17-2007, 08:47 AM   #302
Here's a good starting point for carpet:
Front:
Springs 0.018 with Kyosho yellow lube on kingpins
Blocks 5 deg - Caster in middle
Camber -1.5
Front Ride Height 3.5mm - 4mm
Rear:
T-plate .062 Med with 2 screws on pod.
Tubes Kyosho yellow grease (I've also used red stuff)
Ride Height: 4mm
Shock:
kit shock 30wt or IRS shock 35wt
Olive center spring
Tires:
Pink rears and double pink or purple fronts depending on the track.
Unregistered is offline   Reply With Quote
Old 09-17-2007, 12:33 PM   #303
Josh Cyrul's Avatar
Hello All,
I've been away the past few days trying to catch up on a lot of stuff as well as spending a bit of time at the hospital with my wife, welcoming our 2nd lil one!! It's scary to think she's bigger and stronger than my firt daughter!! All is well so it means I am back to work.
Yesterday, we did some testing with Mr. Blackstock and found a few very interesting things with the C12. With the current set-ups we use on the C12, we always seem to need just a bit more on-throttle steering and slightly less initial steering into the corner - especially on high bite tracks at the major events. I planned out about 8-12 things I wanted to test with Mike and we only made it to #2 before the day was done and .15-.2 per lap was found..
I'm working on the files right now.... Images, more info coming soon with details on these:
Brushless Upper Pod Plate (3mm graphite)
Brushless Lower Pod Plate (3mm graphite)
Center Shock mount
Destiny, Ko Propo, Hobby Wing, Ulti Racing Tires, Protoform, Xenon Racing, Pivothead, Vizon, TQ Wire & Hella Graphics
Josh Cyrul is offline   Reply With Quote
Old 09-17-2007, 02:54 PM   #304
Trader Rating: 14 (100%+)
Josh, I heard you were making the plates wider to take advantage of the new offset of the new jaco wheels. I was wondering if you were also trying to do anything as far as centering the weight of the BL motors in the pod since they are heavier on what used to be the endbell end of the motors?
crisis641 is offline   Reply With Quote
Old 09-17-2007, 06:59 PM   #305
reilly's Avatar
Yes I believe Josh is balancing the weight for the brushless motor plates.
I'm sure we'll know soon!
reilly is offline   Reply With Quote
Old 09-17-2007, 07:33 PM   #306
rogtsaamokin's Avatar
crisis641, Hey Mike, Good to see ya still interested in Cefx When are you starting to race???
Later Roger T
rogtsaamokin is offline   Reply With Quote
Old 09-17-2007, 07:46 PM   #307
subaru73's Avatar
Default set up
what is the yellow lube you are referring to?I need to get some for my car,thanks for the info.
Old 09-17-2007, 08:43 PM   #308
It's the Kyosho yellow diff grease for gas cars. I think you can order it from www.CEFXraceway.net if your local hobby shop doesn't have it.
Old 09-18-2007, 07:06 AM   #309
champebi's Avatar
Heelo!Mr.Josh Cyrul.
I want communication from you immediately. I informed it of the part which was necessary for an all-Japan championship performed from September 28. You give me an email whether it is answered this request. I ask!
champebi is offline   Reply With Quote
Old 09-18-2007, 07:55 AM   #310
KE4PJO's Avatar
Mr. Blackstock? When did Wayne start racing?
KE4PJO is offline   Reply With Quote
Old 09-19-2007, 08:37 PM   #311
RichChang's Avatar
Anyone racing 1/12th on Sunday?
-Rich
RichChang is offline   Reply With Quote
Old 09-20-2007, 05:34 AM   #312
yep,
I'll be there Rich. Possibly some guys from GR too... What class would you like to run? I'm game for anything.
Jeremy
Jeremy Otis is offline   Reply With Quote
Old 09-20-2007, 06:17 AM   #313
RichChang's Avatar
Ah, cool!
I still have to build my car but my goal is to have it done by Sunday.
I am planning on racing mod since all I have is a 10.5 brushless motor. The batteries I have are probably pretty poopy since I last ran them at last year's Halloween Classic. So, I will most likely dump at the two minute mark.
-Rich
Old 09-20-2007, 07:15 AM   #314
Originally Posted by RichChang View Post
Ah, cool!
-Rich
2 minutes is more then enough time to peal everyone...
Brian Anthony is offline   Reply With Quote
Old 09-20-2007, 08:08 AM   #315
Maybe I'll loan the LiPo to Rich so he can run it out the back door. It'll give him an extra 6 minutes to take out BA Baracus.
The Racing Thread chicagokenji Micro and Mini Scales 8 02-20-2007 07:40 AM
CEFX Raceway - Summer Racing Schedule Josh Cyrul Track Locator Forum 0 05-30-2006 05:16 PM
Drag racing thread mrgsr Australian Racing 4 11-05-2005 01:10 AM
GS Racing S.U.T. Thread Fatboy Joe Monster Trucks 5 07-27-2004 07:53 AM
Mad-Rip Racing Thread (where 'd it go?) amusicwiz Florida Racing 1 03-28-2004 07:03 PM
