CEFX Racing Thread.
#166
Kylayfield - I sent a private message to you. In the information that I sent to you, give me communication if I do not understand it.
#167
Thanks a lot! I have a good idea where to start from now.
#168
Any chance of someone posting Blackstock and Micro's setups from the Nats? Thanks
#169
Big B - Coming soon is a CEFX C12 "Japan Spec" kit that will include a thin t-bar rather than a thick as well as a 2.5mm bi-directional chassis. I just cut some up last week to start shipping over to Japan so I have to get the info finished up. The kits will be out asap and you will be able to buy the chassis seperately....
#171
Big B - Thanks!
Travis's Seattle Set-up:
.020 Front Springs
1.5 Camber
Castor (both shims up front)
Medium Chassis
4mm Front Ride Height
1 Degree Toe Out
Jaco Purple Prism Front tires @ 1.67 - No glue
15,000 Kyosho grease on kingpins
35wt Center Shock Oil (IRS Nickle Coated)
Olive Spring
.062 Medium T-bar
.030 shim under the front of the t-bar
Only 2 screws in the t-bar/bottom plate
Rear width 6.68"
Jaco Pink Prism Rear tires @ 1.75 - No glue
3.5mm rear ride height
Blackstock's Seattle Set-up:
Same as Travis with these exceptions:
Jaco Double Pink Prism Front tires @ 1.65 w/glue
Jaco Pink Prism Rear tires @ 1.70 - No glue
.020 shim under the front of the t-bar
3.5mm Front Ride Height
Rear width @ 6.72"
.020 Front Springs
1.5 Camber
Medium Chassis
1 Degree Toe Out
Olive Spring
.062 Medium T-bar
Rear width 6.68"
Rear width @ 6.72"
#172
Big B - Thanks!
.020 Front Springs
1.5 Camber
Medium Chassis
1 Degree Toe Out
Olive Spring
.062 Medium T-bar
Rear width 6.68"
Rear width @ 6.72"
.020 Front Springs
1.5 Camber
Medium Chassis
1 Degree Toe Out
Olive Spring
.062 Medium T-bar
Rear width 6.68"
Rear width @ 6.72"
#174
I lent someone my instruction manual for the CEFX C12 EVO2. Can someone please look at their instructions to see how many axle spacers are used on each side of the rear axle? Thanks in advance...
#175
Regardless of what the directions say to do the best thing would be for you to locate the center line of your car and mark under the bottom plate. Once you have the center line measure from it to the left and then measure to the right. Shim it till you have the exactly the same measuremnts on both sides. You may have a few more shims on one side then the other bit that's O.K. as long as it measures out. I would run it to the max Roar legal 172"
Make sure you have tires on the car
Travis
Travis
#176
Sorry,
I meant 172mm not inches...
#177
I think the manual said 4 but I can't remember the thickness.
#178
I have shims the same thickness as the kit shims. Is that just for the left side?
Anyhow, I wanted to see what the instructions said, then I could just start from there to add shims to each side equally to take some of the guess work out of it.
#179
#180
4 of the kit axle shims on the left side only.
