Motor Break In Help >
Motor Break In Help
Motor Break In Help
Old 02-19-2007, 09:52 AM
Default Motor Break In Help
I am currently running stock and a trinity spec motor(MUST use spec brushes as well) The question I have for you guys is what do you recommend using to dip the motors into while breaking them in. I cannot get a good answer from anyone at the track I race at and I am trying to get a little speed. Any information that you could provide me with would greatly help.
jeffbhhs is offline
Old 02-19-2007, 11:08 AM
Charles Godwin's Avatar
No need to put it in anything. Just break the brushes in for 2mins at 2v. Skim the comm, replace the brushes, clean and re-oil the motor bushings regulary and you'll be fine.
Charles
Charles Godwin is offline
Old 02-19-2007, 11:32 AM
RaceAce701's Avatar
Trader Rating: 87 (99%+)
spec brushes need to b broke in alot longer run it for about 5 min and add a drop of oops to speed the break in process
RaceAce701 is offline
Old 02-19-2007, 12:09 PM
Super Moderator
Marcos.J's Avatar
Trader Rating: 217 (100%+)
break them in water like the Tamiya silver cans 2 minutes in water at 2v should be enough
Marcos.J is offline
Old 02-19-2007, 01:28 PM
when you goto break them in, use D batteries...
do not use like a GFX or any kind of motor break in util when water dipping. just batteries.
MManson is offline
Old 02-19-2007, 01:33 PM
Super Moderator
Marcos.J's Avatar
oops i forgot i have 2cell packs built for that purpose
Marcos.J is offline
Old 02-19-2007, 05:01 PM
wallyedmonds's Avatar
if this motor is like a silver can than do this if you like.
in water for 30 sec out of water to dry a bit stop motor and lube the bushings(if the motor has bearings dont do the water thing)
run at 1v for 30min with a fan on it like the crc one.
can you post a pic of the motor so i know what one it is this would help.
wallyedmonds is offline
Old 02-20-2007, 09:11 PM
Thanks for all the replies, the motor is a rebuildable and it has bushings not bearings. It looks very similar to this motor
http://www2.towerhobbies.com/cgi-bin...?&I=LXNL80&P=7
Its has stand up brushes. I just cannot seem to get good speed from the motor...
jeffbhhs is offline
Old 02-21-2007, 08:14 AM
RaceAce701's Avatar
iv talk with alont the the guys that run street spec on oval they tweek the spring so they are stiffer and break it in for 15 minuts and never ever take the brush out till you need to cut it
the brushed ar every hard and take forever to break is
you will never get good speed from its al about gearing
