Old 02-18-2007, 07:56 PM   #1
CRASH's Avatar
Trader Rating: 26 (100%+)
Default Spool vs Diff vs One-Way
Just curious as to what everyone thinks is the best: Type of tires, Type of surface, etc...
I have been using a spool, with rubber tires on carpet. Most people tell me I need to put a diff in or use a one-way but not a spool.
I have been having fairly good success with it just curious as to what everyone elses take is?
Thanks,
CRASH is offline   Reply With Quote
Old 02-18-2007, 08:09 PM   #2
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Well I didn't like the spool at all with foam. I'm going to the diff, and then maybe back to the one way. The Spool sucked. Usually I'll give tests like that more of a chance but I hated it that much. Maybe if the traction were higher? I don't know. The spool had a good mod feel though. The slower 4300 motor it didn't flow like a one way would with the slower motor.
UN4RACING is offline   Reply With Quote
Old 02-18-2007, 08:16 PM   #3
CRASH's Avatar
I saw your car run, I know it didn't work for you. Haven't seen you since.
Later,
Old 02-18-2007, 09:42 PM   #4
tbeardmore's Avatar
Spool on carpet with rubber tires works!
BMI DB10R, Corally RDX PHi, BMI 12R..!!
Need a "real" car... contact me at:
www.beardmorechevy.com -or- www.beardmoresubaru.com
tbeardmore is offline   Reply With Quote
Old 02-18-2007, 09:50 PM   #5
UN4RACING's Avatar
Later,
You wont see me till that dang spool is out either.
Old 02-19-2007, 02:24 AM   #6
Trader Rating: 30 (100%+)
I think this partly comes down to driving style. I tried a spool and I hated it. Diff in the front seems like a decent compromise if you're not comfortable with a one-way. I think the one-way could be quicker if you don't mind the rear end being a little loose. This is of course on asphalt that I'm driving on and only my personal opinion.
wrxnfx is offline   Reply With Quote
Old 02-19-2007, 02:58 AM   #7
regradless of what being said of those spool, diff, and one-way,
its just an option,
mostly I prefer spool with the expense of more front drive train wear than diff or one-way, but I might try/use other option on different track,
To quench your curiosity, whether it is useful for you or not,
I suggest you should give yourself full 1 or 2 day trying each of that option in your favourite track, if necessary track your laptime on each of them,
it may not easy and takes time for getting proper setup to suit your driving style, anyway it would give you good lesson,
what I understand is that, each of them need different setup and different approach on driving it.
Faiz is offline   Reply With Quote
Old 02-19-2007, 04:40 AM   #8
CRASH's Avatar
That is what I will be running up in Omaha this weekend. Looks like its going to be anawsome weekend.
Later,
Old 02-19-2007, 04:41 AM   #9
CRASH's Avatar
its just an option,
I think I will try that over the next couple of weeks.
Run the spool and the one-way and track the lap times.
Later,
Old 02-19-2007, 05:26 AM   #10
Skiddins's Avatar
I've tried all three types on tight carpet tracks, and the spool always gives mne the best lap times.
Just tighten up a ball diff a lot to give yourself a spool that can take impacts.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 02-19-2007, 05:38 AM   #11
John Tag's Avatar
Trader Rating: 42 (100%+)
Rubber tires on carpet I ran a One way .. 1 way packed with grease to slow reaction makes it real easy to drive and gives fast lap times and you can drive it real hard.....
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,[email protected]
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 02-19-2007, 06:03 AM   #12
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
i don't use grease in mine....I'm sure you drive better with grease but putting grease will slow the car down... Give Faster lap time don't see how...
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 02-19-2007, 06:16 AM   #13
dawgmeat's Avatar
he made the A-main at the birds and he also pass this info onto me and it did make car easy to drive and my laps time improves
dawgmeat is offline   Reply With Quote
Old 02-19-2007, 06:42 AM   #14
Charles Godwin's Avatar
More consitant i guess
Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 02-19-2007, 07:04 AM   #15
Yeti35's Avatar
I think personally it is all in how you drive and what works best for you. I love a spool for outdoors and was using it w/ rubber on carpet up untill we changed the layout. For some reason it did not seem to work as well for me on this layout so I am going to try a one way next. I have heard and been told that a spool is not always consistant on carpet. I think it all boils down to driving style as well.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Diff Spool dieseldog20 Monster Trucks 0 05-28-2008 02:54 PM
ONE WAY, SPOOL, OR DIFF WHICH IS BETTER ? agent 007.5 Electric Off-Road 10 11-17-2007 04:44 AM
Spool - One way - Diff GSP Electric On-Road 12 08-07-2007 07:53 AM
Spool,Diff,or One-way RKeasler Electric On-Road 17 02-19-2005 04:17 PM
Locked Diff "Spool Vs Std Diff OHBRAD Electric On-Road 1 07-05-2004 12:35 AM
