Old 07-30-2008, 09:17 AM   #46
TwoTone's Avatar
Originally Posted by Logika View Post
Is there spool for xray?
I'm looking at getting the MultiDiff, allows you to set it as a solid axle, solid axle with one way or normal one way.
I was reading the Set up book from XRay and it mentions using a rear solid axle on high grip tracks, anyone tried this?
TwoTone is offline   Reply With Quote
Old 08-05-2008, 01:03 AM   #47
Kajman's Avatar
Originally Posted by Tubaboy View Post
K Thanks. My car is a used XXX-S that I got last summer and started racing this summer. I'm new to the whole on-road thing and still figuring it all out. Next hobby order, I'll snag a Spool Diff and give that a shot.
Eventually I plan on upgrading to a TC5 but that will probably happen this winter at the earliest.
Paul
So which did you find best for xxx-s? Spool, diff or one way? One way in my opinion brings too much trouble over gains, diff works fine, but burns sometimes without reason (?), spool didn't try yet, tightening front diff to the maxx will be the same as spool?
XXX-S G+, XXX-S, TRF 415MS, SCTE 2.0, SCTE TLD, Kyosho DRX VE
Kajman is offline   Reply With Quote
Old 08-05-2008, 06:06 AM   #48
decibels's Avatar
no you can still slip your diff even when done up extremely tight!! With spool there is no slip at all!!
Team Wave Speedies
Thunder power lipo's
flying fox rc
!!And an idiot with a controller!!
decibels is offline   Reply With Quote
Old 08-05-2008, 12:22 PM   #49
tc3team's Avatar
true, but be prepared to wear the diff out quicker when its set tighter, the balls and plates don't like it usually.
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 08-06-2008, 04:29 AM   #50
decibels's Avatar
well to be honest when i do it up that tight i usually put old standard balls standard thrust and old plates and thick anti wear grease so it doesnt matter!! lol
Team Wave Speedies
flying fox rc
Old 08-06-2008, 07:20 AM   #51
auzzy_mate's Avatar
Default Spool testing
Hello Thread,
I have a ta05ms which i have always run with ball diff. I have been for so long changing the way i drive to match the car, but NO MORE!
I will be doing testing off different diffs this weekend on an outdoor, good gripping track with good size straights and some tightish hairpins.
I will be running a 540 J-type motor and testing a 9-ball diff, a 16-ball diff, a one-way and a spool. I am leaning towards the spool as i have been told it will be able to serve me well, but this test will give me a great pool of data to actually see the difference.
Any tips will be appreciated and i will let you know my results on Monday.
Ben
Australia
auzzy_mate is offline   Reply With Quote
Old 08-06-2008, 07:26 AM   #52
Kajman's Avatar
Do you have possibility to test overdrive/underdrive diffs too?
Old 08-06-2008, 09:36 AM   #53
Trader Rating: 19 (100%+)
Send a message via AIM to teammidget lilB
Asphault rubber always spool....Rubber on carpet always oneway!
Bryan "Lil B" Ford
U.S. Army @ Camp Humphreys, South Korea
teammidget lilB is offline   Reply With Quote
Old 08-06-2008, 09:43 AM   #54
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
slightly wrong
rubbertires + burshless = always spool nomatter if it's asphalt or carpet
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 08-06-2008, 10:02 AM   #55
When running rubber/asphalt with stock, going to BL 13.5 most likely. Looks like some prefer one-way, some prefer spool. Is it dependent on the track then?
stocker is offline   Reply With Quote
Old 08-06-2008, 10:30 AM   #56
Trader Rating: 1 (67%+)
Originally Posted by Martin Hofer View Post
slightly wrong
Wrong........nothing is always in carpet racing........its all traction and layout dependent.
Josh Hohnstein is offline   Reply With Quote
Old 08-06-2008, 01:57 PM   #57
act2007's Avatar
Trader Rating: 46 (100%+)
Here's some general guide for the front Multi-diff options: (pictured!)
Read the fine print where it says "Best when..."
Personally, it has to do also with your driving style. Smooth or aggressive.
It really comes down to personal preference. I don't think there's
right or wrong here. Hope this helps for some of you guys!
act2007 is offline   Reply With Quote
Old 08-12-2008, 05:58 PM   #58
ckoetsch's Avatar
Trader Rating: 18 (100%+)
does the t2 008 come with their multi diff.
Sick Graphics - KYOSHO RB6.6 - "If you ain't first you're last" R. Bobby
NW Hobbies of Albany and Dave's RC Tracks of Hubbard.
ckoetsch is offline   Reply With Quote
Old 11-22-2008, 08:39 PM   #59
alcyon's Avatar
guys, yesterday at a medium traction track, the surface temp was somethging like 90Celcius. i ran a 11.5 BL motor, with a front one way, and the car was very stable lots of steering and i could even overtake a guy with 416 with spool with the same motor. its a very large track.
so then later i put in a 4R BL motor with the same setup, the car was completely unctrolabble, as soon as i punch the throttle with a little steering it will spin out, same when i let off throtthle and turn. now my question is, can a front ball diff solve my no traction problem with the 4R, without changing any springs or oil? my fornt springs are harder than rears. funny how the one way works with the 11.5 but not for the 4R.
alcyon is offline   Reply With Quote
Old 11-22-2008, 11:22 PM   #60
Originally Posted by auzzy_mate View Post
Hello Thread,
Ben
Australia
Any updates on your testing?
Diff Spool dieseldog20 Monster Trucks 0 05-28-2008 02:54 PM
ONE WAY, SPOOL, OR DIFF WHICH IS BETTER ? agent 007.5 Electric Off-Road 10 11-17-2007 04:44 AM
Spool - One way - Diff GSP Electric On-Road 12 08-07-2007 07:53 AM
Spool,Diff,or One-way RKeasler Electric On-Road 17 02-19-2005 04:17 PM
Locked Diff "Spool Vs Std Diff OHBRAD Electric On-Road 1 07-05-2004 12:35 AM
