Help please with interference >
Old 02-18-2007, 05:25 AM
Wing Chun's Avatar
Default Help please with interference
Hi guy's
I raced last night and got major interference, I run a Ko Pro po VFS-1 hara 2.2. I use a ultimate shotkie diode and a cap. I also use a much more shotkie as a extra precaution at the same time. I used a orion V2 8x1 and checked the enbell capacitor and that was fine the light was working. There was no one on or near my frequence I was using and I have never had the problem until 3 weeks ago and I have not changed anything. My comm has plenty of beef on it still. Is there anything I can buy to help with this problem and do any of you guy's have any idea's on how to help get ride of this problem. With out saying spectrum please.
Thanks in advance
Addam
Wing Chun is offline
Old 02-18-2007, 06:36 AM
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Did you try trueing the comm and replaceing the brushes and cleaning it?
UN4RACING is offline
Old 02-18-2007, 07:10 AM
Charles Godwin's Avatar
Are the brushes run-in? I had a bit of glitching because i didn't run them in long enough. Is there any dirt and dust in the receiver and speedo case? That can cause a bit of interference.
Charles
Charles Godwin is offline
Old 02-18-2007, 02:42 PM
Wing Chun's Avatar
Thanks Guy's for your help on this
2 days before the race I fully rebuilt the car and did the com and ran in the brushes. I have checked the receiver and servo and they are clean. Do you guy's know of any way to stop this. I once noticed that Surikan had 4 small motor caps on his endbell, would any of this help or is there something else I can do.
Addam
Old 02-19-2007, 05:45 AM
tc3team's Avatar
Its a long shot, but make sure your crystals have a good fit, I had to very slightly bend the pins inwards and it stopped me getting interference once.
hth
tc3team is offline
Old 02-19-2007, 06:31 AM
Boosta's Avatar
Trf what tranny are you using and how old is it? i suffered with interferance for ages and tried everything to get rid of it (new rx,xtal, changed wiring around etc) then found that it was the throttle pot on the tranny used a diffrent tranny and viola problem solved. might be worth a try
Boosta is offline
Old 02-19-2007, 09:29 AM
imjonah's Avatar
Default Related question
Does AM interfere with FM
Say I have a channel 4 FM Radio, will someone using an AM CHannel 4 radio interfere with me?
imjonah is offline
Old 02-19-2007, 10:52 AM
Iceracer's Avatar
Yes the AM signal will be seen as noise and interference.
Iceracer is offline
Old 02-19-2007, 02:57 PM
Wing Chun's Avatar
Hi Boosta
It is a Ko Mars II. IT is in great nick. It is 2 years old.
Thanks Mate
Addam
Old 02-19-2007, 03:17 PM
Iceracer's Avatar
Does the problem only occur at the track? Can you make it happen on the bench?
Iceracer is offline
Old 02-19-2007, 08:28 PM
try 3 pieces of servo tape under your reciever and speedo ..! has worked for me for many years !!! over 18 . in all my cars !!!! also ran Orion v2 8 turn and 10t without problems give it a try . and good luck !!!!
mb racer is offline
Old 02-20-2007, 01:31 AM
Boosta's Avatar
Originally Posted by TRFMAD
Hi Boosta
Thanks Mate
Addam
no worries dude mine was a ko vantage II with the dodgy pot so may be worth a try even if it's just to rule it out. Hope you get it sorted fella interferance is the worst for sure
Boosta is offline
Old 02-20-2007, 04:09 AM
Wing Chun's Avatar
Happen's at the track and even in practice when no one is around at all. Never on the work desk. I also never get servo twitch just just between the speedy and motor.
Thanks Mate
Addam
Old 02-20-2007, 04:33 AM
AngryAsian's Avatar
My car never glitched on the desk.
But when you run it OUTSIDE and at range. sometimes it'll do something a bit nasty. Don't count on the desk test. It doesn't work!!
Hows the antenna?
Tx voltage?
Position of esc cap? Too near to the Rx?
Wiring? - near the Rx?
Battery connectors - solid connections? No loose fittings?
Motor leads - all solid? No bad soldering?
Inside of Rx case - clean? No carpet, dust etc?
Rx connectors - all solid? No nicks and cuts?
Tx - sure it works? Didn't drop it recently did you?
Xtals - does it work better on another set?
Chassis - no CF contacting electrical components?
Servo - not too much for the BEC? - Check your linkages.
Just a check-list.. some might've been mentioned before.
AngryAsian is offline
Old 02-20-2007, 05:44 AM
Have you moved the PT from where you normally have it? I had glitching from this and it started glitching less that 5ft away from where i was standing. Moved it back to the usual spot where i have it and it was cured.....
Charles
