Old 03-21-2003, 02:17 AM   #16
Cole Trickle's Avatar
Originally posted by M Ignacio
If you had a choice for touring what would it be? The Ko Propo 2143 or the Ko Propo 2123?
The difference is the FET wire and 0,08 sec. versus 0,06 sec. / 60 deg.
You dont need a ESC with a FET wire. The included manual shows how to do it.
Will 0,02 sec. make a difference? I dont know, but personally, I took the 2123, just to be sure.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 03-21-2003, 02:25 PM   #17
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
2143 vs 2123 sv S9550
Get the 2143, It's fast enough and takes a beating. If you need space then the S9550 is okay, you do feel the diff between the .08 and .11. I coulnd't feel much diff between the .06 and .08 of the 2143 and 2123. So to me the 2143 was the sweet spot (and I got it used for $60 which made it sweeter)
ChristopherKee is offline   Reply With Quote
Old 03-22-2003, 10:57 PM   #18
skibum989's Avatar
I don't know, I just got a KO 2123 for my XXXS, and tested it out today. The performance of that servo was incredible, like Cole said, the ability to change direction in the middle of a chicane in the blink of an eye was awesome. I also love the resolution, it's so precise and centers perfectly every time. Also, wouldn't a servo with a coreless motor last longer than a non-coreless servo? (Or would that even matter)
Ryan Robison
SeattleRCRacers.com - come race with us!
skibum989 is offline   Reply With Quote
Old 03-24-2003, 12:32 PM   #19
One thing I really like about the KO 2123, is the FET wire.
Most power supplys, got a build in safety circuit. Because they dont like too large currents. So if the current gets too high, they simply shut down to protect them self.
Even though many high end ESC got BEC's with 6 volt / 3 amps, they probably got a similar self protecting device. So if a servo in the peak exceeds 3 amps, they dont get it. This gets even worse, if the BEC is a cheaper one.
By nature, this cannot occur with the FET wire.
Old 03-25-2003, 05:09 AM   #20
Ian
ok thanks for all the replies....i just bought a KO2143 and it's really smooth when moved by hand compared to my Airtronics digital servo...by the way would coating the metal gears with Tamiya Anti Wear Grease be a good idea??
Ian is offline   Reply With Quote
Old 03-25-2003, 05:22 AM   #21
It might void the warranty.
elnitro is offline   Reply With Quote
Old 03-25-2003, 05:40 AM   #22
Ian ,
I had read from somewhere that we must careful about the type of grease to use with the servo gears.The reason is that some type of grease will vaporized when it's hot and its vapor may cause problem with motor brushes.
tifosi
tifosi is offline   Reply With Quote
Old 03-25-2003, 11:32 AM   #23
Ian
I'm convinced that you already got a high end servo - if anything can be done to improve it, KO already have done it for you.
Old 03-26-2003, 04:03 AM   #24
dtm
dtm's Avatar
Send a message via ICQ to dtm
No No No...if you have ever used the anti wear grease you will understand. The original servo comes with plenty of grease. If you need to do a rebuild then use Tamiya ceramic grease.
dtm is offline   Reply With Quote
Old 03-30-2003, 05:30 PM   #25
ijnek's Avatar
Send a message via ICQ to ijnek
the KO2143 servo comes with a coreless motor inside if i remember correctly...with ball bearings also...but not a gd idea 2 grease it...u still got circuit boards inside...
ijnek is offline   Reply With Quote
FS: LRP Quantum Comp BESC. KO2143 Servo, PT Keith Billanti R/C Items: For Sale/Trade 3 01-02-2006 09:21 AM
