Reedy Neo Rotors
Originally Posted by rcdougie
I have a Reedy Neo 2 star and the rotor broke apart. Does Reedy/Lrp sell replacement rotors? Ive looked around on the net and cant find anything. Will the Novak rotors fit? Thanks
LRP is selling now a sintered rotor in Europe. It may fit in your motor as well.
Actually the SS series rotor will fit, you just need to make a small hole in the plastic endball. I have done this with mine and it worked perfectly fine. Another racer has also done this but instead of making a hole in the endball for the shaft to stick out he ground down the end of the shaft. The Velocity rotors will not fit though, and I'm not sure about the upgraded rotor for the SS motors. The performance also did not drop, and if it does it's not enough for me to notice.
